Hi everyone!
I have an Ecobee Smart WiFi that uses Homekit to integrate with my HAos. The Ecobee app allows me to set different different comfort settings like “home”, “away”, “sleep”, “custom”, etc but its based on a schedule instead of based on outdoor and indoor temperature.
I tried to create an automation so that when we’re in Summer Season, Ecobee can Choose the appropriate option to run AC at a certain temp or to run fan only, based on both the outside temp (via Weather integration) and the indoor temp (via Ecobee thermostat). If I can get this to work, then I’d try to create an automation for each season.
The problem is that the automation hasn’t kicked on, which I believe is due to using Season in the “When” section. Does this mean it would only trigger at the start of the season? Should I use something else?
I also set an “If” timeframe from 8am-12am, which I can remove if its part of the problem. It’s just that I was hoping to set the thermostat to a sleep mode after 12am, so that the AC shuts off and we revert to ceiling fans for bedtime. (Definitely not implementing this in the winter since it gets super cold. LOL)
I’ve also realized that I can’t seem to set the automation to check the temperature conditions every 2 hours and Choose the appropriate option. Putting a “repeat” just forces the action to do so, back-to-back, instead of it actually waiting 2hrs to check conditions and then choose which option is best.
I’m hoping that you all can take a look and see if there’s another way to do this, that will actually work. Here’s the long and nonsensical yaml I have so far, before I got lost in it. LOL
alias: House Temps in Summer
description: ""
triggers:
- trigger: state
entity_id:
- sensor.season
to: summer
- trigger: state
entity_id:
- sensor.season
to: summer
- trigger: state
entity_id:
- sensor.season
to: summer
conditions:
- condition: time
after: "08:00:00"
before: "00:00:00"
actions:
- choose:
- conditions:
- condition: numeric_state
entity_id: sensor.thermostat_ecobee_current_temperature
above: 75
- condition: state
entity_id: weather.local_wx
attribute: temperature
state: 75-105
for:
hours: 0
minutes: 5
seconds: 0
sequence:
- action: climate.turn_on
metadata: {}
data: {}
entity_id: climate.thermostat_ecobee
- action: climate.set_temperature
metadata: {}
hvac_mode: cool
target_temp_high: 75
target_temp_low: 73
temperature: 75
alias: Set to COOL if warm indoors and warm outdoors
- conditions:
below: 75
- condition: state
state: 75-105
for:
hours: 0
minutes: 5
seconds: 0
sequence:
metadata: {}
data: {}
metadata: {}
hvac_mode: cool
target_temp_low: 73
temperature: 75
alias: Set to COOL if cool indoors and warm outdoors
- conditions:
above: 75
- condition: state
state: 69-74
for:
hours: 0
minutes: 5
seconds: 0
sequence:
metadata: {}
data: {}
metadata: {}
hvac_mode: fan_only
target_temp_high: 76
target_temp_low: 75
temperature: 77
alias: Set to FAN ONLY if warm indoors and cool outdoors
- conditions:
below: 75
- condition: state
state: 0-73
for:
hours: 0
minutes: 5
seconds: 0
sequence:
metadata: {}
data: {}
metadata: {}
hvac_mode: heat
target_temp_high: 77
temperature: 75
target_temp_low: 74
alias: Set to FAN ONLY if cool indoors and cool outdoors
default:
metadata: {}
data: {}
metadata: {}
temperature: 75
target_temp_low: 74
hvac_mode: cool
mode: single
