I paid Amazon to remove the ads thinking that would have done it, but it did not as you say.
In addition to Wallpanel, I also installed the ActionTiles app from the Amazon App Store and I think that has the same/similar effect of keeping the lock screen from appearing. I just keep them both running for now as persistent apps (I’m not noticing any performance issues with them running in the background).
Are you guys aware that the HD8 (2018) can be rooted? The process can be found at XDA Developers and I can confirm it works. They also have a working LineageOS ROM for that devices.
I’ve noticed both Wallpanel and Fully supports MQTT. I wonder if it would be possible to send a push message or instruction to “wakeup”, not from sleep but from screensaver mode, before the lock screen kicks in. I’ve just successfully removed the adds, but wonder if the FireTablet will still go on lockscreen.
Even with ads removed, FireOS still forces the lock screen when the screen wakes up. The best bet is to root the device and flash a custom ROM if you’re able. I rooted and flashed my 8" Fires with LineageOS and they are so much faster and more reliable.
I believe MQTT in Fully Kiosk is informational-only right now, there doesn’t appear to be a way to send commands to Fully over MQTT, but it has a pretty good REST interface, and I started putting together a quick custom component for HA to control Fully over the REST interface: Fully Kiosk Browser Custom Component
if you use Fully, then there is no need to root, remove ads, or flash a rom.
just use fully to avoid the ads.
edit: i got firetabs 7 and 10 as dashboards on my wall, and i never removed ads or screenlocks, or anything. just default firetab.
with fully i avoid that the firetab goes to sleep and locks.
i never see ads, unless i manually restart the devices.
How often did you have to manually restart the devices? I found that mine got painfully slow on FireOS after running for about two weeks. With LineageOS they’ve been much faster and haven’t needed manually rebooted after a couple weeks like they did with FireOS.
For anyone that might find this post in the future, you can remove the lockscreen ads and most of amazon bloatware with Fire Toolbox. You can also add Google Playstore and more to it with this.
To disable the lockscreen completely, do the following:
Install Activity Launcher from Google Play or APKPure
Open app and scroll down, select Settings and find the activity Settings$ScreenLockSuggestionActivity by doing a search for com.android.settings.password.ScreenLockSuggestionActivity in the toolbar at the top.
I was unable to do this with Activity Launcher on my Kindle Fire 7 2015. The only Lock settings I could find were “Lock Screen Passcode” and “SIM card lock settings”.
Also, com.android.settings.password was not available either.
Anybody here figure out how to automate fire tablet reboot?
I have Fully Kiosk set to launch HA on boot but the video keeps breaking and killing the app doesn’t fix video playback.
Only a reboot fixes the video issue.
I don’t have root access but I haven’t looked into gaining it in a while.
I can confirm this works brilliantly - if screen never goes fully off, but fully displays a #00000 screensaver, it looks the same - BUT the Amazon lock screen never kicks in. Genius! Turns on when I approach the table (camera sensor detects motion) so tablet can stay dark on the wall until someone approaches - might be too discreet for guests, but I’ll figure out a nice animated screensaver at some point (aka never) - but for internal users, this is about the perfect dedicated wall tablet you could ask for. Great way to reuse tablets and extend their life until screen dies and they hit the landfill. I paid by perpetual license for Fully Kiosk Browser right away.
