Hi Marc,
It’s basic, but helps me with adjustment the settings for the perfect (I hope ever) control of my sunscreens
See my config below.
# screens group sensor
# @author : RKl
# @last update : 18/08/2019
# @package : none
# @description : Template sensor for sunscreen conditions states
# @url : https://www.home-assistant.io/components/sensor.template/
# Woonkamer down
sensors:
wk_blokkering_button_display:
value_template: >-
{% if is_state('input_boolean.disable_automatic_sunscreens', 'off') %} True
{% else %} False
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
wk_sun_above_horizon:
value_template: >-
{% if is_state('sun.sun', 'above_horizon') %} True
{% else %} False
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
wk_sun_above_horizon_time:
value_template: >-
{% if (now().timestamp())|timestamp_custom('%H:%M') >= ( as_timestamp(state_attr('sensor.sunrise','today')) + (1.0*3600) )|timestamp_custom('%H:%M') %} True
{% else %} False
entity_id:
- sensor.sunrise
- sensor.time
icon_template: >-
mdi:check-outline
mdi:alert-outline
# als--> huidige tijd (custom gemaakt) groter of gelijk is dan sensor.sunrise attribute tijd 'today' + 7,5uur (custom gemaakt) dan true. 9u = groter/gelijk dan bv 7u+1u
# - condition: sun
# after: sunrise
# after_offset: '01:00:00'
sensors:
wk_sun_below_horizon_time:
value_template: >-
{% if (now().timestamp())|timestamp_custom('%H:%M') <= ( as_timestamp(state_attr('sensor.sunset','today')) - (3.5*3600) )|timestamp_custom('%H:%M') %} True
{% else %} False
entity_id:
- sensor.sunset
- sensor.time
icon_template: >-
mdi:check-outline
mdi:alert-outline
# als--> huidige tijd (custom gemaakt) kleiner is dan sensor.sunset attribute tijd 'today' - 3,5uur (custom gemaakt) dan true. 15u = kleiner/gelijk dan bv 3,5u voor 21u
# - condition: sun
# before: sunset
# before_offset: "-03:30:00"
sensors:
wk_max_wind_gust:
# Wind strenght - in km/h (equeal as windkracht 7)
value_template: >-
{% if states('sensor.br_arnhem_wind_gust') | int < 60 %} True
{% else %} False
icon_template: >-
{% if states('sensor.br_arnhem_wind_gust') | float < 60 %}
mdi:check-outline
mdi:alert-outline
sensors:
wk_max_rain_next_hour:
# Almost no rain in the next 60 minutes is predicted
value_template: >-
{% if states('sensor.br_arnhem_precipitation_forecast_average') | int < 10 %} True
{% else %} False
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
wk_min_outdoor_temp:
# Above the 16 degrees outsite temperature
value_template: >-
{% if states('sensor.outdoor_temperature') | int > 16 %} True
{% else %} False
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
wk_min_inside_temp:
# Above the 20 degrees in Living room.
value_template: >-
{% if states.climate.woonk_keuken.attributes.current_temperature > 20 %} True
{% else %} False
entity_id:
- climate.woonk_keuken
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
wk_outside_weather_summary_down_up:
#If one of the sensor values (see screens_sensor.yaml) is True and therefore this sensor is down for 30 min the condition will be True.
value_template: >-
{% if is_state('sensor.screen_woonkamer_down_by_clouds', 'down') %} True
{% else %} False
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
wk_min_ha_running:
# Voorkomt dat automation na restart HA gelijk uitgevoerd wordt.
value_template: >-
{% if states('sensor.ha_runtime_in_hours') | float > 0.05 %} True
{% else %} False
icon_template: >-
mdi:check-outline
mdi:alert-outline
#datetime
#{{now()}}
#timestamp
#{{as_timestamp(now())}}
#add 1 hour (3600 seconds)
#{{as_timestamp(now())+ (1*60*60)}}
#display as local time
#{{(as_timestamp(now())+ (1*60*60)) | timestamp_local}}
#display just the hour
#{{(as_timestamp(now())+ (1*60*60)) | timestamp_custom("%H",true)}}
# {% as_timestamp(now().strftime("%H") >= "7") and (now().strftime("%H") <= "16") %} True
sensors:
wk_time_frame_for_execution:
value_template: >-
{% if now().hour > 7 and now().hour < 16 %} true
{% else %} False
entity_id:
- sensor.time
icon_template: >-
mdi:check-outline
mdi:alert-outline
# - condition: time
# after: '07:00:00'
# before: '16:00:00'
sensors:
wk_months_for_execution:
# Starting in Maart dus groter dan 2 (feb) en ending in oktober dus kleiner dan 10
value_template: >-
{% if (now().month >= 3) and (now().month <= 9) %} True
{% else %} False
entity_id:
- sensor.date
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
wk_last_execution_time:
# prevents that automation is triggered multiple times in a short amount of time. Checks last time automation is triggered, if more then 2700 seconds (45min), condition becomes True
value_template: >-
{% if (as_timestamp(now()) - as_timestamp(states.automation.sunscreen_woonkamer_down.attributes.last_triggered) | int > 2700) %} True
{% else %} False
entity_id:
- sensor.time
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
wk_down_last_execution_up_older_then_down:
# can only be triggered if timestamp of last_triggered time UP is kleiner/gelijk than the timestamp of last_triggered time of the "screen down" automation.
value_template: >-
{% if (as_timestamp(states.automation.sunscreen_woonkamer_down.attributes.last_triggered) | int <= as_timestamp(states.automation.sunscreen_woonkamer_up.attributes.last_triggered) | int) %} True
{% else %} False
entity_id:
- sensor.time
icon_template: >-
mdi:check-outline
mdi:alert-outline
# Keuken Down
sensors:
keu_blokkering_button_display:
value_template: >-
{% else %} False
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
keu_sun_above_horizon:
value_template: >-
{% else %} False
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
keu_sun_above_horizon_time:
value_template: >-
{% if (now().timestamp())|timestamp_custom('%H:%M') >= ( as_timestamp(state_attr('sensor.sunrise','today')) + (7.5*3600) )|timestamp_custom('%H:%M') %} True
{% else %} False
entity_id:
- sensor.sunrise
- sensor.time
icon_template: >-
mdi:check-outline
mdi:alert-outline
# als--> huidige tijd (custom gemaakt) groter of gelijk is dan sensor.sunrise attribute tijd 'today' + 7,5uur (custom gemaakt) dan true. 15u = groter/gelijk dan bv 7u+7,5u
# - condition: sun
# after: sunrise
# after_offset: '07:30:00'
sensors:
keu_sun_below_horizon_time:
value_template: >-
{% if (now().timestamp())|timestamp_custom('%H:%M') <= ( as_timestamp(state_attr('sensor.sunset','today')) - (1.5*3600) )|timestamp_custom('%H:%M') %} True
{% else %} False
entity_id:
- sensor.sunset
- sensor.time
icon_template: >-
mdi:check-outline
mdi:alert-outline
# als--> huidige tijd (custom gemaakt) kleiner is dan sensor.sunset attribute tijd 'today' - 1,5uur (custom gemaakt) dan true. 15u = kleiner/gelijk dan bv 1,5u voor 21u
# - condition: sun
# before: sunset
# before_offset: "-01:30:00"
sensors:
keu_max_wind_gust:
value_template: >-
{% else %} False
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
keu_max_rain_next_hour:
value_template: >-
{% else %} False
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
keu_min_outdoor_temp:
value_template: >-
{% else %} False
entity_id:
- sensor.outdoor_temperature
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
keu_min_inside_temp:
value_template: >-
{% else %} False
entity_id:
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
keu_outside_weather_summary_down_up:
value_template: >-
{% if is_state('sensor.screen_keuken_down_by_clouds', 'down') %} True
{% else %} False
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
keu_min_ha_running:
value_template: >-
{% else %} False
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
keu_time_frame_for_execution:
value_template: >-
{% if now().hour > 12 and now().hour < 20 %} true
False
entity_id:
- sensor.time
icon_template: >-
mdi:check-outline
mdi:alert-outline
# - condition: time
# after: '12:00:00'
# before: '20:00:00'
sensors:
keu_months_for_execution:
value_template: >-
{% else %} False
entity_id:
- sensor.date
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
keu_last_execution_time:
value_template: >-
{% if (as_timestamp(now()) - as_timestamp(states.automation.sunscreen_keuken_down.attributes.last_triggered) | int > 2700) %} True
{% else %} False
entity_id:
- sensor.time
icon_template: >-
mdi:check-outline
mdi:alert-outline
sensors:
keu_down_last_execution_up_older_then_down:
value_template: >-
{% if (as_timestamp(states.automation.sunscreen_keuken_down.attributes.last_triggered) | int <= as_timestamp(states.automation.sunscreen_keuken_up.attributes.last_triggered) | int) %} True
{% else %} False
entity_id:
- sensor.time
icon_template: >-
mdi:check-outline
mdi:alert-outline
# Sunscreens
title: Sunscreens # Tooltip
icon: mdi:projector-screen
cards:
- type: entities
title: Sturing Screens
show_header_toggle: false
entities:
- type: section
label: "Woonkamer_DOWN"
- type: entities
entity: sensor.wk_blokkering_button_display
- type: entities
entity: sensor.wk_sun_above_horizon
- type: entities
entity: sensor.wk_sun_above_horizon_time
- type: entities
entity: sensor.wk_sun_below_horizon_time
- type: entities
entity: sensor.wk_max_wind_gust
- type: entities
entity: sensor.wk_max_rain_next_hour
- type: entities
entity: sensor.wk_min_outdoor_temp
- type: entities
entity: sensor.wk_min_inside_temp
- type: entities
entity: sensor.wk_outside_weather_summary_down_up
- type: entities
entity: sensor.wk_min_ha_running
- type: entities
entity: sensor.wk_time_frame_for_execution
- type: entities
entity: sensor.wk_months_for_execution
- type: entities
entity: sensor.wk_last_execution_time
- type: entities
entity: sensor.wk_down_last_execution_up_older_then_down
- type: section
label: "Keuken_DOWN"
- type: entities
entity: sensor.keu_blokkering_button_display
- type: entities
entity: sensor.keu_sun_above_horizon
- type: entities
entity: sensor.keu_sun_above_horizon_time
- type: entities
entity: sensor.keu_sun_below_horizon_time
- type: entities
entity: sensor.keu_max_wind_gust
- type: entities
entity: sensor.keu_max_rain_next_hour
- type: entities
entity: sensor.keu_min_outdoor_temp
- type: entities
entity: sensor.keu_min_inside_temp
- type: entities
entity: sensor.keu_outside_weather_summary_down_up
- type: entities
entity: sensor.keu_min_ha_running
- type: entities
entity: sensor.keu_time_frame_for_execution
- type: entities
entity: sensor.keu_months_for_execution
- type: entities
entity: sensor.keu_last_execution_time
- type: entities
entity: sensor.keu_down_last_execution_up_older_then_down
