How to automate my awning (sunscreen)
I want to have a steady reading for x minutes above a certain value. If it drops below that value the timer should start over. this wil make sure the screens only go down if it has been sunny for a whilexyg
I use statistics sensors for that purpose. To calculate the average over e.g. 3 measurements. Primarily to eliminate spikes.
Right now I only have my phone, will answer your question later.
Hi all,
I’m struggling with my template value. I have also a automation for my covers. I want a overview in a display to see or all my conditions are true or false. The most of them I have already, but I can’t get the right one of these
- condition: sun
after: sunrise
after_offset: ‘07:30:00’
How can I make a sensor with output true or false.
{% if is_state(‘sun.sun’, ‘above_horizon’) + (for example 7,5 hours) %} True
That is actually not as simply as you would hope :sunny:
Home Assistant only contains the time of the Next Sunrise. So once the sun has risen, you can only get the time of tomorrow’s sunrise. I think this template will get you an approximation of what you want:
{{ as_timestamp(now()) | timestamp_custom('%H:%M:%S', true) > ( as_timestamp(state_attr('sun.sun','next_rising')) + (7*3600)+1800 ) | timestamp_custom('%H:%M:%S', true) }}
Basically it says: if the time is after sunrise + 7,5 hours, then it’s true. But it looks at the time of tomorrow’s sunrise, not today’s. So there might be a slight difference (usually just a matter of minutes, depending on where you are in the world. If you want the exact number, I would advice you to install the sun2 custom component. It does contains today’s time of sunrise.
Sorry Arnold, forgot to answer you. My automation is indeed giving me the desired behaviour. I could make it more perfect, but because I can also control the awning manually there’s never really an issue. Dark Sky is accurate enough. But now I have my own weather station, so that temperature is also going in the mix soon. I don’t really know of another weather source for HA that containts today’s predicted temperature.
Did you get your timer to work correctly or do you need some help with that?
Roelof, I am on holiday right now but i did not manage to get the working correct.
But I haven’t tried your solution yet because i thought i had it working in node red. But I was wrong. I still like to use my own realtime lux values, but the hue sensors update only every few minutes.
When i am back i’ll try some more.
Roelof,
I will try it and let you know. thx for replying :slight_smile:
This could be a suggestion too. @Railittle
Roelof,
Thx for your extra suggestion. I will keep this in my mind. At this moment I want to have it all automatic and not with manual input.
I have made these sensor. And it works perfect. Based on your code.
    sensors:
      wk_sun_above_horizon_time:
        value_template: >-
          {% if (now().timestamp())|timestamp_custom('%H:%M') >= ( as_timestamp(state_attr('sensor.sunrise','today')) + (1.0*3600) )|timestamp_custom('%H:%M') %} True
          {% else %} False
          {% endif %}
I did not integrate the dark sky sensors yet but did set up the statistics sensors and that works a lot better. Thanks for the suggestion.
Soon i will implement the dark sky sensors and use at least the wind sensor.
I am trying to build my own rain sensor so that after a few drops the screens will go up.
Nice, DIY :slightly_smiling_face: Still, in my experience Buienradar predicted rain is better. When my personal weather station picks it up the awning is quite wet already.
Just a quick question, how did you make this view?
Like nice !
Hi Marc,
It’s basic, but helps me with adjustment the settings for the perfect (I hope ever) control of my sunscreens :slight_smile:
See my config below.
#   screens group sensor
#   @author         :   RKl
#   @last update    :   18/08/2019
#   @package        :   none
#   @description    :   Template sensor for sunscreen conditions states
#   @url            :   https://www.home-assistant.io/components/sensor.template/
# Woonkamer down
    sensors:
      wk_blokkering_button_display:
        value_template: >-
          {% if is_state('input_boolean.disable_automatic_sunscreens', 'off') %} True
          {% else %} False
          {% endif %}
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      wk_sun_above_horizon:
        value_template: >-
          {% if is_state('sun.sun', 'above_horizon') %} True
          {% else %} False
          {% endif %}
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
        value_template: >-
          {% else %} False
          {% endif %}
        entity_id:
          - sensor.sunrise
          - sensor.time
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
#     als--> huidige tijd (custom gemaakt) groter of gelijk is dan sensor.sunrise attribute tijd 'today' + 7,5uur (custom gemaakt) dan true.      9u = groter/gelijk dan bv 7u+1u
#      - condition: sun
#        after: sunrise
#        after_offset: '01:00:00'
    sensors:
      wk_sun_below_horizon_time:
        value_template: >-
          {% if (now().timestamp())|timestamp_custom('%H:%M') <= ( as_timestamp(state_attr('sensor.sunset','today')) - (3.5*3600) )|timestamp_custom('%H:%M') %} True
          {% else %} False
          {% endif %}
        entity_id:
        - sensor.sunset
        - sensor.time
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
#     als--> huidige tijd (custom gemaakt) kleiner is dan sensor.sunset attribute tijd 'today' - 3,5uur (custom gemaakt) dan true.      15u = kleiner/gelijk dan bv 3,5u voor 21u
#      - condition: sun
#        before: sunset
#        before_offset: "-03:30:00"
    sensors:
      wk_max_wind_gust:
      # Wind strenght - in km/h  (equeal as windkracht 7)
        value_template: >-
          {% if states('sensor.br_arnhem_wind_gust') | int < 60 %} True
          {% else %} False
          {% endif %}
        icon_template: >-
          {% if states('sensor.br_arnhem_wind_gust') | float < 60 %}
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      wk_max_rain_next_hour:
      # Almost no rain in the next 60 minutes is predicted
        value_template: >-
          {% if states('sensor.br_arnhem_precipitation_forecast_average') | int < 10 %} True
          {% else %} False
          {% endif %}
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      wk_min_outdoor_temp:
      # Above the 16 degrees outsite temperature
        value_template: >-
          {% if states('sensor.outdoor_temperature') | int > 16 %} True
          {% else %} False
          {% endif %}
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      wk_min_inside_temp:
      # Above the 20 degrees in Living room.
        value_template: >-
          {% if states.climate.woonk_keuken.attributes.current_temperature > 20 %} True
          {% else %} False
          {% endif %}
        entity_id:
        - climate.woonk_keuken
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      wk_outside_weather_summary_down_up:
      #If one of the sensor values (see screens_sensor.yaml) is True and therefore this sensor is down for 30 min the condition will be True.
        value_template: >-
          {% if is_state('sensor.screen_woonkamer_down_by_clouds', 'down') %} True
          {% else %} False
          {% endif %}
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      wk_min_ha_running:
      # Voorkomt dat automation na restart HA gelijk uitgevoerd wordt.
        value_template: >-
          {% if states('sensor.ha_runtime_in_hours') | float > 0.05 %} True
          {% else %} False
          {% endif %}
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
#datetime
#{{now()}}
#timestamp
#{{as_timestamp(now())}}
#add 1 hour (3600 seconds)
#{{as_timestamp(now())+ (1*60*60)}}
#display as local time
#{{(as_timestamp(now())+ (1*60*60))  | timestamp_local}}
#display just the hour
#{{(as_timestamp(now())+ (1*60*60))  | timestamp_custom("%H",true)}}
# {% as_timestamp(now().strftime("%H") >= "7") and (now().strftime("%H") <= "16") %} True
    sensors:
      wk_time_frame_for_execution:
        value_template: >-
          {% if now().hour > 7 and now().hour < 16 %} true
          {% else %} False
          {% endif %}
        entity_id:
        - sensor.time
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
#      - condition: time
#        after: '07:00:00'
#        before: '16:00:00'
    sensors:
      wk_months_for_execution:
      # Starting in Maart dus groter dan 2 (feb) en ending in oktober dus kleiner dan 10
        value_template: >-
          {% if (now().month >= 3) and (now().month <= 9) %} True
          {% else %} False
          {% endif %}
        entity_id:
        - sensor.date
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      wk_last_execution_time:
      # prevents that automation is triggered multiple times in a short amount of time. Checks last time automation is triggered, if more then 2700 seconds (45min), condition becomes True
        value_template: >-
          {% if (as_timestamp(now()) - as_timestamp(states.automation.sunscreen_woonkamer_down.attributes.last_triggered) | int > 2700) %} True
          {% else %} False
          {% endif %}
        entity_id:
        - sensor.time
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      wk_down_last_execution_up_older_then_down:
      # can only be triggered if timestamp of last_triggered time UP is kleiner/gelijk than the timestamp of last_triggered time of the "screen down" automation.
        value_template: >-
          {% if (as_timestamp(states.automation.sunscreen_woonkamer_down.attributes.last_triggered) | int <= as_timestamp(states.automation.sunscreen_woonkamer_up.attributes.last_triggered) | int) %} True
          {% else %} False
          {% endif %}
        entity_id:
          - sensor.time
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
# Keuken Down
    sensors:
      keu_blokkering_button_display:
        value_template: >-
          {% else %} False
          {% endif %}
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      keu_sun_above_horizon:
        value_template: >-
          {% else %} False
          {% endif %}
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      keu_sun_above_horizon_time:
        value_template: >-
          {% if (now().timestamp())|timestamp_custom('%H:%M') >= ( as_timestamp(state_attr('sensor.sunrise','today')) + (7.5*3600) )|timestamp_custom('%H:%M') %} True
          {% else %} False
          {% endif %}
        entity_id:
          - sensor.sunrise
          - sensor.time
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
#     als--> huidige tijd (custom gemaakt) groter of gelijk is dan sensor.sunrise attribute tijd 'today' + 7,5uur (custom gemaakt) dan true.       15u = groter/gelijk dan bv 7u+7,5u
#      - condition: sun
#        after: sunrise
#        after_offset: '07:30:00'
    sensors:
      keu_sun_below_horizon_time:
        value_template: >-
          {% if (now().timestamp())|timestamp_custom('%H:%M') <= ( as_timestamp(state_attr('sensor.sunset','today')) - (1.5*3600) )|timestamp_custom('%H:%M') %} True
          {% else %} False
          {% endif %}
        entity_id:
          - sensor.sunset
          - sensor.time
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
#     als--> huidige tijd (custom gemaakt) kleiner is dan sensor.sunset attribute tijd 'today' - 1,5uur (custom gemaakt) dan true.      15u = kleiner/gelijk dan bv 1,5u voor 21u
#      - condition: sun
#        before: sunset
#        before_offset: "-01:30:00"
    sensors:
      keu_max_wind_gust:
        value_template: >-
          {% else %} False
          {% endif %}
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      keu_max_rain_next_hour:
        value_template: >-
          {% else %} False
          {% endif %}
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      keu_min_outdoor_temp:
        value_template: >-
          {% else %} False
          {% endif %}
        entity_id:
          - sensor.outdoor_temperature
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      keu_min_inside_temp:
        value_template: >-
          {% else %} False
          {% endif %}
        entity_id:
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      keu_outside_weather_summary_down_up:
        value_template: >-
          {% if is_state('sensor.screen_keuken_down_by_clouds', 'down') %} True
          {% else %} False
          {% endif %}
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      keu_min_ha_running:
        value_template: >-
          {% else %} False
          {% endif %}
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      keu_time_frame_for_execution:
        value_template: >-
          {% if now().hour > 12 and now().hour < 20 %} true
          {% else %}
            False
          {% endif %}
        entity_id:
          - sensor.time
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
#      - condition: time
#        after: '12:00:00'
#        before: '20:00:00'
    sensors:
      keu_months_for_execution:
        value_template: >-
          {% else %} False
          {% endif %}
        entity_id:
          - sensor.date
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      keu_last_execution_time:
        value_template: >-
          {% if (as_timestamp(now()) - as_timestamp(states.automation.sunscreen_keuken_down.attributes.last_triggered) | int > 2700) %} True
          {% else %} False
          {% endif %}
        entity_id:
          - sensor.time
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
    sensors:
      keu_down_last_execution_up_older_then_down:
        value_template: >-
          {% if (as_timestamp(states.automation.sunscreen_keuken_down.attributes.last_triggered) | int <= as_timestamp(states.automation.sunscreen_keuken_up.attributes.last_triggered) | int) %} True
          {% else %} False
          {% endif %}
        entity_id:
          - sensor.time
        icon_template: >-
            mdi:check-outline
          {% else %}
            mdi:alert-outline
          {% endif %}
# Sunscreens
    title: Sunscreens # Tooltip
    icon: mdi:projector-screen
    cards:
      - type: entities
        title: Sturing Screens
        show_header_toggle: false
        entities:
          - type: section
            label: "Woonkamer_DOWN"
          - type: entities
            entity: sensor.wk_blokkering_button_display
          - type: entities
            entity: sensor.wk_sun_above_horizon
          - type: entities
            entity: sensor.wk_sun_above_horizon_time
          - type: entities
            entity: sensor.wk_sun_below_horizon_time
          - type: entities
            entity: sensor.wk_max_wind_gust
          - type: entities
            entity: sensor.wk_max_rain_next_hour
          - type: entities
            entity: sensor.wk_min_outdoor_temp
          - type: entities
            entity: sensor.wk_min_inside_temp
          - type: entities
            entity: sensor.wk_outside_weather_summary_down_up
          - type: entities
            entity: sensor.wk_min_ha_running
          - type: entities
            entity: sensor.wk_time_frame_for_execution
          - type: entities
            entity: sensor.wk_months_for_execution
          - type: entities
            entity: sensor.wk_last_execution_time
          - type: entities
            entity: sensor.wk_down_last_execution_up_older_then_down
          - type: section
            label: "Keuken_DOWN"
          - type: entities
            entity: sensor.keu_blokkering_button_display
          - type: entities
            entity: sensor.keu_sun_above_horizon
          - type: entities
            entity: sensor.keu_sun_above_horizon_time
          - type: entities
            entity: sensor.keu_sun_below_horizon_time
          - type: entities
            entity: sensor.keu_max_wind_gust
          - type: entities
            entity: sensor.keu_max_rain_next_hour
          - type: entities
            entity: sensor.keu_min_outdoor_temp
          - type: entities
            entity: sensor.keu_min_inside_temp
          - type: entities
            entity: sensor.keu_outside_weather_summary_down_up
          - type: entities
            entity: sensor.keu_min_ha_running
          - type: entities
            entity: sensor.keu_time_frame_for_execution
          - type: entities
            entity: sensor.keu_months_for_execution
          - type: entities
            entity: sensor.keu_last_execution_time
          - type: entities
            entity: sensor.keu_down_last_execution_up_older_then_down
Ah yes, that’s smart. Thank you for sharing!
hi @gieljnssns
i like your config. where did you get the sun energy values?
Do you mean this?
          - condition: numeric_state
            entity_id: sensor.huidige_opbrengst
            above: 1200
This comes from my Smappee, this is the current solar energy from my solar panels
ah ok thanks. then i can t use this value :slight_smile:
This thread is really helpful. My challenge was to automate the closing of the sunscreens in the morning when a very hot day is expected (based on the forecast of dutch Buienradar).
I have created 3 input_booleans:
  wind_low_tomorow:
    name: "Wind < 5 Bft tomorow"
    icon: mdi:weather-windy
  temp_high_tomorow:
    name: "Temp >24 C tomorow"
    icon: mdi:weather-sunny
  rain_low_tomorow:
    name: "Rain < 0.2 mm tomorow"
    icon: mdi:weather-pouring
Every evening these booleans are set with the latest forecast:
automation:
  - alias: Read temp tomorrow
    initial_state: 'on'
      platform: time
      at: '22:00:00'
    condition:
      entity_id: sensor.br_temperature_1d
      above: 24
      service: input_boolean.turn_on
      entity_id: input_boolean.temp_high_tomorow
  - alias: Read Windforce tomorrow
    initial_state: 'on'
      platform: time
      at: '22:00:00'
    condition:
      entity_id: sensor.br_wind_force_1d
      below: 5
      entity_id: input_boolean.wind_low_tomorow
  - alias: Read Rain tomorrow
    initial_state: 'on'
      platform: time
      at: '22:00:00'
    condition:
      entity_id: sensor.br_rain_1d
      below: 0.2
      entity_id: input_boolean.rain_low_tomorow
And the automation to get the screens down early morning :slight_smile:
  - alias: Screens down
    initial_state: 'on'
      platform: sun
      event: sunrise
      offset: +00:30:00
    condition:
      condition: and
      conditions:
        - condition: state
          state: 'on'
        - condition: state
          state: 'on'
        - condition: state
          state: 'on'
     - service: switch.turn_on
       entity_id: switch.screens
And an automation to get the screens up when the wind or rain are too strong:
  - alias: Screens up
    initial_state: 'on'
    - platform: time
      at: '17:00:00'
    - platform: sun
      event: sunset
      offset: -02:00:00
    - platform: numeric_state
      above: 4
      for:
        minutes: 5
      entity_id: sensor.br_precipitation_forecast_total
      above: 0.2
      entity_id: sensor.br_irradiance
      below: 100
      for:
        minutes: 5
     - service: switch.turn_off
A big thank you to all of you!
Hi @Emphyrio , your automations look awesome. I am installing my smart roller shades tomorrow, and i will be using a lot of your ideas. Thank you for that. Anyhow, since you are using this for a couple of years now, are there any new insights that would be worth sharing? Or is it ‘smooth sailing’ since then?
I am still using the settings as described above. No need to adapt.
Two changes worth mentioning:
  1. I switched from DarkSky to OpenWeatherMap for today’s temperature forecast. DarkSky is no longer free.
  2. Because we are working from home, I built some more options for manual control into my Lovelace dashboard. It looks like this:
Controls straight on the dashboard. The button ‘Manual control’ shows until what time Home Assistant won’t interfere with the awning position:
Popup that appears when you click on the manual-control-button (‘Handbediening’):
