I am trying to set the value of the number.solax_battery_charge_max_current in below example.
I have tried various options read through numerous community posts but still can get it to work.
Setting the input_number in below example works perfectly but not the entity_id : number.solax_battery_charge_max_current.
I have also tried configuring with automation but got nowhere.
Any help will be appreciated.
All of the below is in a template.yaml. file which is included in the configuration.yaml.
- sensor:
- name: Required Charge current
unique_id: f45c8c8b-b494-4d9f-9988-278cedaa1e14
icon: mdi:current-dc
unit_of_measurement: A
state: >
{% set batvoltage = states('sensor.solax_battery_voltage_charge') | float(0) %}
{% set chargebatcapacity = states('sensor.solax_chargeable_battery_capacity') | float(0) %}
{{ ((chargebatcapacity / 3) / batvoltage) | round(1) }}
- trigger:
- platform: time
at: "18:47:00"
- service: input_number.set_value
entity_id: input_number.charge_current
value: "{{ states('sensor.required_charge_current') | float(0) | round(1) }}"
- service: number.set_value
entity_id: number.solax_battery_charge_max_current
value: "{{ states('input_number.charge_current') | float(0) | round(1) }}"
petro
(Petro)
May 10, 2024, 11:41am
2
Just make a template number.
- number:
availability: >
{% set entities = 'sensor.solax_battery_voltage_charge', 'sensor.solax_chargeable_battery_capacity' %}
{{ entities | map('has_value') | reject(False) | list | count == entities | count }}
state: >
{% set voltage, capacity = ['sensor.solax_battery_voltage_charge', 'sensor.solax_chargeable_battery_capacity'] | map('states') | map('float') | list %}
{{ ((capacity / 3) / voltage) | round(1) }}
set_value:
value: "{{ value }}"
Thank you for getting back to me. I am very new to HA so I appreciate the help.
I am trying to figure out how to action this on a trigger. I should have been cleared in my original post on what I am trying to achieve:
Each day at 12 pm, my solar system is set to charge the battery from the grid, and it stops charging at 3 pm. At 12 pm each day, I want to work out the maximum charge current to charge the battery fully by 3 p.m. This is calculated by dividing the charging capacity by 3 hours and then dividing the result by the charging voltage to get the required current. I want to use the result of this calc to set the entity number.solax_battery_charge_max_current.
the number entity “number.solax_battery_charge_max_current” is part of an integration I installed.
Baseds on your feedback above I have tried implementing it as follow.
- trigger:
- platform: time
at: "12:00:00"
number:
availability: >
state: >
set_value:
petro
(Petro)
May 10, 2024, 12:45pm
4
you’d make a separate automation that triggers at 12 and uses the number entity. You would not add the trigger to the template entity.
The number entity was missing the step condition and unit_of_measurement was invalid.
Template looks like this now
- number:
unique_id: 47c94e28-2f68-4666-97c7-4f13f17d464f
step: 0.1
availability: >
state: >
set_value:
and the automation created is as follow but does not work:
- id: '1715348471973'
alias: Set Max charge Current
description: ''
- platform: time
at: '21:42:00'
condition: []
metadata: {}
data: {}
entity_id: number.required_charge_current
mode: single
petro
(Petro)
May 10, 2024, 2:29pm
6
What’s not working? Logs?
2024-05-10 22:44:00.270 ERROR (MainThread) [homeassistant.components.automation.set_max_charge_current] Set Max charge Current: Error executing script. Invalid data for call_service at pos 1: required key not provided @ data[‘value’]
2024-05-10 22:44:00.270 ERROR (MainThread) [homeassistant.components.automation.set_max_charge_current] Error while executing automation automation.set_max_charge_current: required key not provided @ data[‘value’]
Edwin_D
(Edwin D.)
May 10, 2024, 3:21pm
8
Well, the error says it all. Set it, but set it to what? you did not supply the new value in the (2nd) automation.
petro
(Petro)
May 10, 2024, 3:41pm
9
You need to supply a value… what value are you trying to put here?
petro
(Petro)
May 10, 2024, 3:59pm
10
I have a sneaking suspicion that there’s some communication issues here, and that you really want to set the value of this equation at a specific time.
And if that’s the case, you can just do this in a single automation without a helper entity.
description: ''
- platform: time
at: '21:42:00'
variables:
voltage: "{{ states('sensor.solax_battery_voltage_charge') }}"
capacity: "{{ states('sensor.solax_chargeable_battery_capacity') }}"
condition: []
metadata: {}
data: {}
value: "{{ ((capacity / 3) / voltage) | round(1) }}"
mode: single
Finally got it working. There was definitely a communication gap. Thanks for your persistence, petro. Below are a few small tweaks to what you have proposed. I am very new to YAML, and syntax is so critical. In this case, the float condition to be added to value:,
- id: '1715383332005'
alias: Set Charge current 2
description: ''
- platform: time
at: 07:53:00
condition: []
- variables:
voltage: '{{ states(''sensor.solax_battery_voltage_charge'') | float(0) }}'
capacity: '{{ states(''sensor.solax_chargeable_battery_capacity'') | float(0)
current: '{{ ((capacity / 3) / voltage) | float(0) | round(1) }}'
metadata: {}
value: '{{ current | float(0) }}'
mode: single
Francois3d:
voltage
If you default voltage to 0, but are dividing by voltage, it is mathematically forbidden in defaultcase and if voltage is 0 in other cases. You should define, what should happen in those cases as well.
petro
(Petro)
May 11, 2024, 9:49am
13
Float isn’t needed anywhere, you should have been able to copy/paste exactly what I wrote
It gave me an error in the traces of the automtion as well as in the logs. It said Float required.
petro
(Petro)
May 12, 2024, 2:21pm
15
Did you use the ui? If yes, you should have removed the exterior quotes.
You are correct again : I changed it back to exactly as you wrote it and it worked. However, the automation did not trigger if I edited the time trigger in the Studio code server. I had to go into the UI to setup the time trigger and save. In case you are wondering, I did in the Studio code server.
