I have a “Aeotec ZW090 Z-Stick Gen5 EU” and a “Qubino ZMNHND1 Flush 1D relay”.
If the “Qubino ZMNHND1 Flush 1D relay” is turned on I would like to turn itself off after 2 seconds it has been on.
I have try to make an automatisation but until now it never worked.
Look carefully at the last line in your automation, where you indicate the entity_id of the light to be turned off. There is an extra : in it that should be removed.
Change this:
"entity_id:":"Livingplafond2"
to this:
"entity_id":"light.livingplafond2"
In addition, if Livingplafond2 is a light, then the service you are using is incorrect.
Change this:
automation.turn_off
to this:
light.turn_off
If it is an automation, then leave it as automation.turn_off.
Finally (I think), replace friendly_name with entity_id here:
That’s good news! Please mark my post as the Solution so that other people, with similar issues, can find it more readily. Only you, the author, of this topic can tag a post with Solution. It will automatically appear as a link under your first post and a checkmark will appear next to the topic’s title (indicating it has an accepted solution).
