Hello!
I’m having issues, specifically with retaining the entity’s name through the exported flow below. What I don’t understand is that the iOS notification does exactly what I want, but the output to the TTS-ultimate node calls the name “payload” instead of the device’s name like the iOS push notification.
Where am I going wrong here? I have a number of use cases where it’s helpful to have iOS push notifications, as well as local audio notifications.
I feel it is something simple, yet I can’t figure it out.
P.S. I know I don’t have a connector to the TTS-Ultimate node (since it is broken )
Thank anyone in advance for their help here!
"id": "fad2d312d08edc5d",
"type": "server-state-changed",
"z": "fb106f0953c589ab",
"name": "Indoor Swing Sensors",
"server": "e204944a.31bc78",
"version": 4,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "binary_sensor.swing_indoor_sensors_only",
"entityidfiltertype": "exact",
"outputinitially": true,
"state_type": "str",
"haltifstate": "",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 1,
"output_only_on_state_change": true,
"for": 0,
"forType": "num",
"forUnits": "minutes",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"outputProperties": [
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 580,
"y": 400,
"wires": [
"8abce97126b545bb"
"id": "10b897c87fc08701",
"type": "api-current-state",
"name": "Home?",
"version": 3,
"outputs": 2,
"halt_if": "home",
"entity_id": "group.presence_home",
"blockInputOverrides": false,
"value": "",
"property": "data",
"value": "",
"valueType": "entity"
"for": 0,
"forType": "num",
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 1010,
"y": 440,
"wires": [
"ad751533e42451a4"
"id": "8abce97126b545bb",
"type": "switch",
"name": "On/Off",
"rules": [
"t": "eq",
"v": "off",
"vt": "str"
"t": "eq",
"v": "on",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 790,
"y": 400,
"wires": [
"59daab0a9c2e91df"
"10b897c87fc08701"
"id": "ad751533e42451a4",
"type": "stoptimer",
"duration": "15",
"units": "Second",
"payloadtype": "num",
"payloadval": "0",
"name": "",
"x": 1400,
"y": 380,
"wires": [
"456b4c6727787658"
"id": "f176046f69d4a67c",
"type": "api-call-service",
"name": "Notify Karson's Phone",
"version": 5,
"debugenabled": true,
"domain": "notify",
"service": "mobile_app_karsons_iphone",
"areaId": [],
"deviceId": [],
"entityId": [],
"data": "{\"message\":\"{{payload}} was left open for more than 15 seconds. Save Mr. Kitty!!\"}",
"dataType": "json",
"mergeContext": "",
"mustacheAltTags": false,
"value": "{{payload}} was left open for more than 15 seconds. Save Mr. Kitty!!\"",
"valueType": "str"
"queue": "none",
"x": 2020,
"y": 320,
"wires": [
"id": "438edab5f2ca3b45",
"name": "Notify Amy's Phone",
"version": 5,
"domain": "notify",
"service": "mobile_app_amys_iphone",
"areaId": [],
"deviceId": [],
"entityId": [],
"dataType": "json",
"mergeContext": "",
"outputProperties": [],
"queue": "none",
"x": 2010,
"y": 380,
"wires": [
"id": "172f16309f8ac6ad",
"type": "ttsultimate",
"name": "",
"voice": "en-US",
"ssml": false,
"sonosipaddress": "10.10.100.32",
"sonosvolume": "40",
"sonoshailing": "Hailing_Hailing.mp3",
"config": "a585de9c1021e86d",
"propertyType": {},
"rules": [
"host": "10.10.100.135",
"hostVolumeAdjust": "0"
"host": "10.10.100.196",
"host": "10.10.100.177",
"host": "10.10.100.198",
"host": "10.10.100.176",
"host": "10.10.100.160",
"playertype": "sonos",
"speakingrate": "1",
"speakingpitch": "0",
"unmuteIfMuted": true,
"x": 1990,
"y": 260,
"wires": [
"id": "59daab0a9c2e91df",
"type": "change",
"name": "Stop Timer",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "stop",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1030,
"y": 380,
"wires": [
"ad751533e42451a4"
"id": "456b4c6727787658",
"type": "ha-get-entities",
"name": "Which Sensors?",
"version": 0,
"rules": [
"property": "entity_id",
"logic": "in_group",
"value": "binary_sensor.swing_indoor_sensors_only",
"valueType": "str"
"property": "state",
"logic": "includes",
"value": "on",
"valueType": "str"
"output_type": "split",
"output_empty_results": false,
"output_location_type": "msg",
"output_location": "payload",
"output_results_count": 1,
"x": 1560,
"y": 460,
"wires": [
"3ff8effe4570d0ad"
"id": "3ff8effe4570d0ad",
"type": "template",
"name": "Format Msg",
"field": "payload",
"fieldType": "msg",
"format": "handlebars",
"syntax": "mustache",
"template": "{{payload.attributes.friendly_name}}",
"output": "str",
"x": 1580,
"y": 540,
"wires": [
"b34caa7951060775"
"id": "b34caa7951060775",
"type": "join",
"name": "",
"mode": "custom",
"build": "string",
"key": "topic",
"joiner": ", ",
"joinerType": "str",
"accumulate": false,
"timeout": "",
"count": "",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "",
"reduceFixup": "",
"x": 1800,
"y": 540,
"wires": [
"f176046f69d4a67c",
"438edab5f2ca3b45"
"id": "e204944a.31bc78",
"type": "server",
"name": "Home Assistant",
"version": 5,
"addon": false,
"rejectUnauthorizedCerts": false,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": "30",
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": "at: ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "h23",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": true
"id": "a585de9c1021e86d",
"type": "ttsultimate-config",
"name": "TTS Service",
"noderedipaddress": "10.10.100.3",
"noderedport": "1980",
"purgediratrestart": "purge",
"ttsservice": "googletranslate"
