How to Bosch Room Thermostat II
Hi all
Needed some time to integrate my Bosch Room Thermostat II in a usefull way.
Some hints for others.
My Hardware
  • Bosch Room Thermostat II
  • Bosch Smart Home Controller II
  • Bosch Smart Home App on iPhone
My configuration for presence
  • Presence group, which includes all members of the house
  • An input_select.home_away_holidays (home, away, holidays)
  • Automations, which change the input_select, triggered by changes in the presence group
Desired behavior
  • The target temperature of the thermostat should change, in dependence of home / away / holidays
Implementation Steps
  • Installed the integration for Bosch SHC.
  • Because the Bosch SHC integration does not (yet) support the Room Thermostat II, I installed the HACS component. A lot of thanks to @tschamm for his great work.
  • This allows a service call of bosch_shc.trigger_scenario and to change the desired temperature without messing up. Before I was experimenting with Better Thermostat, which changed my Bosch Thermostat in unwanted ways.
Detailed steps for triggering the scenarios
  • In the Smart Home App for Bosch I did set up three heating schedules (for home, away, holidays). E. g. holidays will be at a temperature of 16.
  • Then I did se tup in the Smart Home App for Bosch three scenarios, each selects the corresponding heating schedule. E. g. scenario holiday selects heating schedule holiday.
  • Reload the Bosch SHC in Home Assistant
  • Restart Home Assistant
  • Controll the entities of the Bosch SHC integration. The defined scenarios in the Bosch App are now available as entities. Example: event.scenario_holidays (entity id)
  • Setup an automation using the service bosch_shc.trigger_scenario. I needed some time to find out the correct syntax.
  - platform: state
    entity_id:
      - input_select.home_away_holiday
    to: Holiday
condition: []
  - service: bosch_shc.trigger_scenario
  • Important step here was the name (Holiday) in the service trigger. First I thought, it has to be the name of the generated entities (event.scenario_holidays, see above). But it has to be the name given in the Smart Home App for Bosch.
  • I added three automations (for home, away, holidays)
Result
  • If I change my input_select.home_away_holiday (by automation or manually), Home Assistant changes my heating schedule on the Bosch Room Thermostat II.
Hi, thanks for the info!
I’d like to ask two questions,if I may:
  • does the implementation you’ve described allow to collect the data from the Thermostats? Like the desired temperature, actual temperature, humidity, etc? I’m currently more interested in the data collection rather than control.
  • Do you know if there is any work being done in the official implementation of the Bosch Smart Home II device?
Thanks!
For each physical device, the integration generates:
Climate entity with state (auto, heat, off) and these attributes (examples):
hvac_modes: auto, heat, off
min_temp: 5
max_temp: 30
target_temp_step: 0.5
preset_modes: none, eco
current_temperature: 22.5
temperature: 21
preset_mode: none
friendly_name: Bosch Bad
supported_features: 17
whereas temperature is the target temperature.
A temperature sensor with state (current temperature) and these attributes:
state_class: measurement
unit_of_measurement: °C
device_class: temperature
friendly_name: Thermostat Bad Temperature
A humidity sensor with state (humidity) and these attributes:
unit_of_measurement: %
device_class: humidity
friendly_name: Thermostat Bad Humidity
Additional entities:
  • A switch for child lock
  • A number for offset
Example statistic of the climate entity
Translation for graphic: Ist-Temperatur = actual temperature, Soll-Temperatur = desired temperature
Example of humidity sensor
Example of temperature sensor
Desired temperature / target temperature
There is no direct sensor available for the target temperature. But you can easily build your own. For example I am tracking, when the valve is open with this template:
{% set target_temp = state_attr('climate.room_climate_bad', 'temperature') %}
{% set current_temp = state_attr('climate.room_climate_bad', 'current_temperature') %}
{% if target_temp > current_temp %}on
{% else %}off
{% endif %}
Meaning you can derive your own sensor for the target temperature with state_attr('climate.room_climate_bad', 'temperature').
Regarding information about the official implementation, I am the wrong source.
Hello everyone.
I’m experiencing issues with installing the Bosch SHC integration (GitHub - tschamm/boschshc-hass: Home Assistant component for accessing Bosch Smart Home Controller using boschshcpy python library.) in Home Assistant.
Hardware I’m using:
  • Smart Home Controller II
  • Radiator Thermostat II
My goal is to manage the thermostats both from the Bosch Smart Home app, which offers advanced temperature and routine management, and from Home Assistant, allowing me to control them directly from my dashboards.
When I purchased these products, I saw that the hub supported Matter, so I assumed integration would be easy. However, I later discovered that the system is quite closed. After several failed pairing attempts, I contacted Bosch support, and they replied:
"We confirm that direct integration of the Bosch Smart Home Controller II with other Matter ecosystems is not currently possible.
To answer your questions, the controller II does in fact provide a ‘Matter bridge’ which converts the signals from the Zigbee 3.0 connection standard into the IP Matter standard.
In this case, the controller II in the Smart Home ecosystem acts as a connection bridge.
You can then make some Smart Home devices visible in other Matter systems.
As you will have noticed, Amazon Alexa is an official partner, so direct integration is possible in the same way as with Apple Home Kit or Google Assistant”
At this point, I looked for an alternative approach and tried the official Bosch SHC integration in Home Assistant. Unfortunately, the thermostats were recognized only as sensor entities and not as climate entities.
I then tried this custom integration:
Unfortunately, I haven’t been able to make it work. I thought the issue might be related to my Home Assistant version being too recent, as the last compatible version mentioned was 2021.1.5. So, I attempted to install this older version, but without success.
The current situation and that of integration that is not configured correctly and shows the following error:
What I have tried so far:
  • Reinstalling the integration by HACS
  • Testing different versions of Home Assistant
  • Testing different versions of HACS
  • Checking file configuration permissions
Despite all my attempts, I haven’t found a solution yet.
I hope I have been clear about the problems I have encountered. I am open to any solution, as long as it allows me to use both the original Bosch app and Home Assistant.
If anyone who works would like to tell me their version of Home Assistant and HACS I would be grateful.
Thanks in advance for your help!
Can you elaborate on this?
I have the thermostat integrated via ZigBee and BetterThermostat (no SHC) and have not noticed issues. Would be good to understand if I’ve missed something that could make my setup more efficient or effective.
I have five thermostats in use. I have defined a separate temperature curve for each one in the Bosch app. For example, I have a higher temperature in the bathroom from 6:00 to 8:00 a.m.
I initially used Better Thermostat as well, and the temperature was adjusted correctly. However, the temperature curve defined in the Bosch app then made adjustments again. There was a constant back and forth between the two algorithms.
I then decided to use the curves in the Bosch app for two reasons:
  1. It is very easy to define different curves for different rooms.
  2. In the Bosch app, I can adjust the temperatures remotely (my Home Assistant only runs locally).
Hello, does anybody tried to integrate the Thermostat II in Home Assistant only using zigbee2MQTT, without the Bosch Controller in the middle? Is it possible?
EDIT: I found this thread Bosch Thermostat 2 - Configuration / Zigbee - Home Assistant Community, probably the answer is "yes" via qrcode? :slight_smile:
