I have a sensor which contains the current number of steps in a session. This sensor produces something like the following:
I.e. this sensor is an increasing value until a walk stops. At that point it is reset to zero.
I would like to create a sensor derived from walking pad steps that would produce a history_stat that is the sum of all the steps in that day: 4151+3284+902=8337.
It seems what I need is a way to calculate the local maxima values for the current day. Does anyone know how to achieve something like this?
You could try the total or total_increasing state classes.
Using total_increasing should give you a value that increases forever corresponding to your total steps (see explanation here). Perhaps not that helpful.
Using total would give you a value that increases throughout the day (I think?), as long as you can also set last_reset to be the start of each day (see explanation here).
Not that I’ve tried either for this type of use case, but that’s where I’d start.
This worked! Thanks for the quick answer!
I’m trying to do the exact same. Adding up the local maxima to get a “Daily Steps” counter. But neither state_class: total nor state_class: total_increasing work for me. Both reset to zero every time the step counter drops to zero.
@Mobius7 How exactly did you solve this? Could you post your yaml?
Solved it myself by using an SQL sensor.
Under Integrations add the “SQL” Integration, then use the following settings:
Column: total_steps
Query:
SELECT
SUM(B.state) +
SELECT A.state
FROM
states as A
INNER JOIN states_meta as A_meta
ON A.metadata_id = A_meta.metadata_id
WHERE
A_meta.entity_id = 'sensor.walkingpad_4'
ORDER BY A.state_id DESC
LIMIT 1
) AS total_steps
FROM
states as A
ON A.metadata_id = A_meta.metadata_id,
states as B
INNER JOIN states_meta as B_meta
ON B.metadata_id = B_meta.metadata_id,
states as C
INNER JOIN states_meta as C_meta
ON C.metadata_id = C_meta.metadata_id
WHERE
AND A.old_state_id = B.state_id
AND B.old_state_id = C.state_id
AND CAST(A.state AS INTEGER) < CAST(B.state AS INTEGER)
AND CAST(C.state AS INTEGER) < CAST(B.state AS INTEGER)
AND strftime('%Y-%m-%d', B.last_updated_ts, 'unixepoch', 'localtime') = strftime('%Y-%m-%d', 'now', 'localtime')
ORDER BY B.state_id DESC
Replace sensor.walkingpad_4 with the name of your step sensor (in both places).
Cacan you please add your code as example. I like to do that also but i dont know how where i put that total stateclass.
i know im late but i was trying to see how others did it and came across this thread so hopefully this will help someone in the future because im sure you have figured it out by now lol but my phone gives me sensor.s25_ultra_steps_sensor then i made a packages folder in my config and put people.yaml under that. then in the people.yaml i have
homeassistant:
utility_meter:
s25_ultra_steps_daily:
source: sensor.s25_ultra_steps_sensor
cycle: daily
s25_ultra_steps_weekly:
cycle: weekly
s25_ultra_steps_monthly:
cycle: monthly
template:
- sensor:
- name: s25_ultra_step_summary
unique_id: s25_ultra_step_summary
state: >
{% set today = states('sensor.s25_ultra_steps_daily') | int(0) %}
{% set yesterday = state_attr('sensor.s25_ultra_steps_daily', 'last_period') | int(0) %}
{% if today > yesterday %}
You've walked {{ today - yesterday }} more steps than yesterday! 🚶♂️💪
{% elif today < yesterday %}
You're {{ yesterday - today }} steps behind yesterday. Keep going! 🏃♂️🔥
{% else %}
Same number of steps as yesterday — try to beat it! 📊
{% endif %}
icon: mdi:walk
make sure your config has
homeassistant:
# Load all YAML files under /config/packages as packages
packages: !include_dir_named packages
still messing with the card but so far its
type: vertical-stack
cards:
- type: custom:mushroom-title-card
title: Step Tracker
alignment: center
- type: grid
columns: 2
square: false
cards:
- type: custom:mushroom-entity-card
entity: sensor.s25_ultra_steps_daily
icon: mdi:shoe-print
layout: vertical
primary_info: state
secondary_info: name
icon_color: green
entity: sensor.s25_ultra_steps_weekly
icon: mdi:calendar-week
layout: vertical
primary_info: state
icon_color: orange
entity: sensor.s25_ultra_steps_monthly
icon: mdi:calendar-month
layout: vertical
primary_info: state
icon_color: purple
entity: sensor.s25_ultra_steps_sensor
icon: mdi:walk
layout: vertical
primary_info: state
icon_color: blue
primary: "{{ states('sensor.s25_ultra_step_summary') }}"
icon: mdi:walk
icon_color: teal
fill_container: true
multiline_primary: true
