How to calculate / subtract two date.time from eachother?
Ok, not sure how those attributes are formatted in the first place.
If you remove the “| int” will that give you another non 0 value?
sorry, that just gives “none”
i think the “time” values are maybe just a string? thehy show as just “13:39” for example?
I found this in another thread.
{% set time = "12:45" %}
{{ (((as_timestamp(strptime(time, "%H:%M"))) - as_timestamp( strptime( now().strftime("%H:%M"), "%H:%M") )) /60) | int}}
It seems to work to calculate a time in string format.
Maybe you can replace “time” and “now” with your sensor attributes?
This will give you the time in minutes (143) between kickofftime and finishtime.
{% set kickofftime = "10:45" %}
{% set finishtime = "13:08" %}
{{ (((as_timestamp(strptime(finishtime, "%H:%M"))) - as_timestamp(strptime(kickofftime, "%H:%M") )) /60) | int}}
Hi I’ve just stumbled upon this thread as I’m trying to do something similar to what OP was doing with working out a departure time. I’ve got the added complication of a TTS automation though.
This thread has been fantastic with figuring out the template for what I want, and I’ve got it to generate a departure time that’s definitely correct, but when I put it into TTS, it will say “…you should set off before x hours, y minutes, zero seconds”.
Here’s the function I use to calculate the departure time:
{{ strptime('08:00', '%H:%M') - strptime(states.sensor.time_to_work.state, '%M') }}
Now how do I separate out the hour and minute values so I can then insert them into the TTS string and make it say “…you should set off before y minutes past x”?
Just tacking onto this thread with a quick question.
The above solutions all use attributes, but I need a state (hours between now and forecast), but below does not resolve
{{as_timestamp(states('sensor.openweathermap_forecast_time')) - as_timestamp(now()) | timestamp_local  }}
gives
TypeError: unsupported operand type(s) for -: 'float' and 'str'
However
{{as_timestamp(states('sensor.openweathermap_forecast_time'))  | timestamp_custom("%H") }}
Results in the hour, expected because forecast_time is a timestamp…
{{states('sensor.openweathermap_forecast_time') | as_datetime - now() }}
results in 0:31:59.997861
Even tried using strptime, no joy
What about
{% set n = as_timestamp(now()) %}
{% set x = as_timestamp( states('sensor.openweathermap_forecast_time') ) %}
{% set t = (n-x) |timestamp_custom('%R') %}
{{ t }}
