Please, how to call effect of the light strip in scripts? I would like to choose Color Wipe, but I don’t know how to do it. Brightness works correctly. Thanks
here is what I found works:
- service: wled.effect
entity_id: light.wled
effect: Spot
intensity: 10
speed: 150
palette: Autumn
I didn’t found that effect in Light help.
I have no wled service.
You must of course make sure that the light you are controlling can actually do the effect you want. If you click on a light (while it’s on) you should get a colourwheel etc. and at the bottom there is a drop down list of effects, see what’s in the list.
start_jeeves:
alias: Start Jeeves
sequence:
- service: light.turn_on
entity_id: light.3d_lamp
effect: "ColorWipe"
I’ve been tried this. Brightness works, but effect no. I must set effect by hand only. In GUI effect has name “Color Wipe”.
Edit: @RoadkillUK tried again, not success. BTW “ColorWipe” is always changed to ColorWipe. From yaml code and from GUI too.
