I do a fair amount of dynamic loading of module files in my custom component.
Users of my custom component have started opening issues about the Detected blocking call to import_module inside the event loop warning.
but for the life of me I cannot figure out how to keep using this but not block the thread. Any suggestions on how to do this? I have read the async dev docs page but I wasn’t able to make it work. I don’t really want to get rid of the dynamic loading…
in line 731 of your init file, this will run it in a thread and not block the loop. Obv, this getModuleInstanceByID method also needs to be async and the upstream modules that call it.
Given that your websocket returns the result of coordinator.async_get_all_modules(), then awaiting it is fine as it needs to complete before it can.
As a note, loadModules itself does not have to be async, but must not block the event loop. As such, using the example i provided before, runs it in another thread and not the event loop, so that this wont block it.
@callback
async def websocket_get_all_modules(hass: HomeAssistant, connection, msg):
"""Publish all module data. This is not retrieved from the store."""
coordinator = hass.data[const.DOMAIN]["coordinator"]
modules = await coordinator.async_get_all_modules()
connection.send_result(msg["id"], modules)
However, now I am getting:
2024-05-24 16:58:46.698 WARNING (MainThread) [py.warnings] /workspaces/core/homeassistant/components/websocket_api/connection.py:229: RuntimeWarning: coroutine 'websocket_get_all_modules' was never awaited
Coroutine created at (most recent call last)
File "/workspaces/core/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
return await handler(request)
File "/workspaces/core/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/workspaces/core/homeassistant/components/http/ban.py", line 85, in ban_middleware
File "/usr/local/lib/python3.12/site-packages/aiohttp_session/__init__.py", line 199, in factory
response = await handler(request)
File "/workspaces/core/homeassistant/components/http/auth.py", line 295, in auth_middleware
File "/workspaces/core/homeassistant/components/http/headers.py", line 32, in headers_middleware
File "/workspaces/core/homeassistant/helpers/http.py", line 73, in handle
result = await handler(request, **request.match_info)
File "/workspaces/core/homeassistant/components/websocket_api/http.py", line 53, in get
return await WebSocketHandler(request.app[KEY_HASS], request).async_handle()
File "/workspaces/core/homeassistant/components/websocket_api/http.py", line 416, in async_handle
async_handle_str(command_msg_data)
File "/workspaces/core/homeassistant/components/websocket_api/connection.py", line 229, in async_handle
handler(self.hass, self, schema(msg))
Internet search is not really helping. What should I do?
