jchh
(my username is my initials (and my first name isn't John))
1
I have I have a Tapo c220 which does not remember its current position. That’s OK.
However, every so often, I get an error that my preset “does not exist”. This occasionally happens when turning the camera on after it has been off for a while. Is there a way to catch the error and retry? I have a script to perform the select.move_to_preset and would like to handle the error inside the script.
script:
tapo_move_to_door:
alias: "Tapo: Point camera at door"
icon: mdi:door
mode: queued
sequence:
- if:
- condition: state
entity_id: switch.tapo_door_camera
state: 'on'
then:
# move to preset
- service: input_select.select_option
entity_id: input_select.tapo_move_to
option: door
# wait for move to complete
- delay: 5
# send message with camera snapshot
- service: script.tapo_notify_snapshot
else:
# notify
- service: script.notify_james
message: "Unable to move to door - camera is off."
The errors in the logs are:
logs
2024-03-26 10:59:56.941 ERROR (MainThread) [homeassistant.components.script.tapo_move_to_door] Tapo: Point camera at door: If at step 1: Error executing script. Error for call_service at pos 2: Option door is not valid for select.tapo_c220_move_to_preset
2024-03-26 10:59:56.941 ERROR (MainThread) [homeassistant.components.script.tapo_move_to_door] Tapo: Point camera at door: Error executing script. Error for if at pos 1: Option door is not valid for select.tapo_c220_move_to_preset
2024-03-26 10:59:56.943 ERROR (MainThread) [homeassistant.components.automation.tapo_auto_on_off] Tapo: Camera control: Choose at step 1: choice 3: Repeat at step 1: If at step 3: Error executing script. Error for call_service at pos 2: Option door is not valid for select.tapo_c220_move_to_preset
2024-03-26 10:59:56.944 ERROR (MainThread) [homeassistant.components.automation.tapo_auto_on_off] Tapo: Camera control: Choose at step 1: choice 3: Repeat at step 1: Error executing script. Error for if at pos 3: Option door is not valid for select.tapo_c220_move_to_preset
2024-03-26 10:59:56.945 ERROR (MainThread) [homeassistant.components.automation.tapo_auto_on_off] Tapo: Camera control: Choose at step 1: choice 3: Error executing script. Error for repeat at pos 1: Option door is not valid for select.tapo_c220_move_to_preset
2024-03-26 10:59:56.945 ERROR (MainThread) [homeassistant.components.automation.tapo_auto_on_off] Tapo: Camera control: Error executing script. Error for choose at pos 1: Option door is not valid for select.tapo_c220_move_to_preset
2024-03-26 10:59:57.003 ERROR (MainThread) [homeassistant.components.automation.tapo_auto_on_off] Error while executing automation automation.tapo_auto_on_off: Option door is not valid for select.tapo_c220_move_to_preset
Any ideas?
I have also asked this question in the Tapo Camera control discord channel, but I think it’s a useful general question as well.
jchh
2
I appreciate the continue_on_error: true option, but I am also interested in a some logic that is “if previous service call errored out, then…”.
Yeah that is not an input select and you have the entity id incorrect. That is why you are having issues. Change your automation to:
then:
# move to preset
- service: select.select_option # change here
entity_id: select.tapo_c220_move_to_preset # and here
option: door
jchh
6
Thanks and well spotted but I mis-pasted and do have it correct in my version
tapo_move_to_door:
icon: mdi:door
mode: queued
sequence:
- if:
- condition: state
state: 'on'
then:
# remember move
option: door
# move to preset
option: door
# wait
- delay: 5
# notify
else:
# notify
I tried to cut the input_select.select_option to avoid confusion as I only use it to remember which of the several scripts (this is one) that I last used. However I cut the select.select_option by accident instead.
Edit: I should make it clear that I did not release my copy/paste mistake until you pointed it out so thanks and apologies for the mislead it caused.
jchh
7
OK, I am going to try this (unedited full script!)
tapo_move_to_door:
icon: mdi:door
mode: queued
sequence:
- if:
- condition: state
state: 'on'
then:
- alias: "Wait until preset is available"
wait_template: "{{ is_state('select.tapo_c220_move_to_preset', 'unknown') }}"
timeout: "00:00:30"
continue_on_timeout: true
- if:
- "{{ wait.completed }}"
then:
# remember move
option: door
# move to preset
option: door
# wait
- delay: 5
# notify
else:
# notify
- service: script.notify_james_loud
message: "Unable to move to door - 'select' not availabe"
else:
# notify
jchh
9
I appreciate your suggestion but the camera never knows where it is (it’s a great camera, but this is its one problem for me).
The state of select.tapo_c220_move_to_preset is always either unknown (when the camera is on) or unavailable (when the camera is off). This is why I got stuck working out what to do. I’m therefore waiting for it to be unknown (meaning it does exist) per your suggestion. I’ve just tried it and it works
It’s not an elegant script right now. Once I can confirm it works when select. select.tapo_c220_move_to_preset is unavailable (may take a couple of days) I’ll replace the nested if/then with choose.
