How to change an icon of an entity to a pic?
how can I change an icon of an entity to my own pic and not from mdi website?
for example to change the persons icon to their real photo
Perhaps it depends on what entity it is?
For sensors you could use template sensor as a wrapper.
With customizing
person.xxx:
  entity_picture: /local/pictures/people/xxx.png
or
switch.xxx:
  entity_picture: /local/pictures/xxx.png
where is that local folder?
how to transfer the pic to the local folder?
I think it depends on what installation you have. Mine is in /config/www.
Same question. I use Samba add-on.
so I have add the pic to: home_assistance/config/www/local/pictures/people/barak.png
and add the below row to the State attributes
entity_picture: /local/pictures/people/barak.png
and still the person entity is blanked, what I’m doing wrong?
anyone can help?
“/local” is mapped to config/www
If you created a local folder under www, it would be:
entity_picture: /local/local/pictures/people/barak.png
Most would not create another local folder under www. Instead, they would have:
/config/www/pictures/people/barak.png
and would reference it like:
… because /local/ points to the config/www folder.
Make sense?
thanks a lot, I took your advice, now its working
the second reply was posted to this topic 1 day ago… :wink:
sorry but I didn’t understand it as solution
any chance someone knows why the pic is rotated ?Screen Shot 2020-02-24 at 22.40.33
the original photo is straight
I don’t know :wink:
and if you rotate it 90 degrees clockwise and upload to /www/? :wink:
tried it but still it didn’t work
do you mean that no matter what you upload its orientation is the same?
have you refreshed your screen/cleared cache/restarted HA?
One option is to add a unique version to the image file name after every rotation change you try. It will force the frontend to update. I use the date and time (YYYYMMDDHHMMSS).
Ex. /config/www/pictures/people/barak_v20200224180600.png
Sometimes caching issues can be hard to overcome even with forced page reloads in a browser.
since upgrading to 0.106 the picture is blanked
I have this in the customize.yaml
person.barak:
  entity_picture: local/pictures/people/barak.jpg
person.almog:
and this in the configuration.yaml
homeassistant:
  customize: !include customize.yaml
any help please
a) roll back
b) search if there is an open issue on Github regarding your situation
c) open a new issue on Github if not b
Add / on front
entity_picture: /local/pictures/people/barak.jpg
