I have a door contact via Hubitat that has an entity id of binary_sensor.kitchen_garage_door_contact. Home Assistant assigned the garage door icon to it instead of the standard door one that it uses on all my other door contacts. Is there a way to change it to the normal default? I don’t want to delete the contact and re-add it as it’s in several automations and I’d probable have to delete from Hubitat as well.
Yes. Edit the entity and change the “Show As” to “Door”.
I would if I could. I have a separate post about my entities panel being different than shown on the web site. This is the dialog tab for the entity in question:
Am I in the right place? I clicked Configuration, Devices & Services, Entities, and then selected the entity. Clicking on the icon in the upper right just shows the history and log.
Update
I restarted HA and the displayed data changed.
