How to change check / scan / update interval for core integrations fe Brother
Hello, I am using “core integration” Brother Printer. The printer is in deep sleep mode most of the time. How or where can I set the check / scan / update interval to 10 minutes, instead of the default 60 seconds. Add a rule for homeassistant.components.brother to the configuration.yaml I tried but it doesn’t work. Thank you for the advice.
