Hello, I’m using vertical stack with several glances cards to display various entities, switches and sensors on my home assistant main screen.
cards:
- entities:
- entity: person.he
- entity: person.she
- entity: binary_sensor.door
- entity: switch.fibaro_system_fgs223_double_relay_switch_2
hold_action:
action: more-info
show_icon: true
show_name: true
tap_action:
action: toggle
type: button
show_name: true
type: glance
- entities:
- entity: sensor.fibaro_system_fgbs222_smart_implant_temperature_2
- entity: sensor.fibaro_system_fgk101_door_opening_sensor_temperature
- entity: sensor.fibaro_system_fgbs222_smart_implant_temperature_3
show_name: true
type: glance
- cards:
- entity: switch.fibaro_system_fgs222_double_relay_switch_2x1_5kw_switch_2
hold_action:
action: more-info
icon: 'mdi:arrow-up-bold-box-outline'
name: Ouvrir les volets
show_icon: true
show_name: true
tap_action:
action: toggle
type: button
hold_action:
action: more-info
icon: 'mdi:arrow-down-bold-box'
name: Fermer les volets
show_icon: true
show_name: true
tap_action:
action: toggle
type: button
type: horizontal-stack
type: vertical-stack
It gives me the nice panel below :
But now, I would like to change the text below the top right button. It switches on and off the light in my garage, but the translation in french is not relevant. It states “Inactif” for Off and “On” for On. I would like to change the text displayed to “Eteint” while off and “Allumé” while on.
I tried to use a binary sensor instead, but then I can’t click on the icon to toggle the light. So I need to keep the switch instance, but I can’t find a way to customize it so that it says Eteint or Allumé.
Is is possible to change this state text ?
