How to change icon in tile card
Hi all,
I wrote down the following code:
- type: custom:vertical-stack-in-card
    cards:
      - type: vertical-stack
        cards:
          - features:
              - type: cover-position
            type: tile
            entity: cover.tapparella_della_camera
            icon: mdi:window-shutter
            color: white
          - type: horizontal-stack
            cards:
              - type: custom:button-card
                tap_action:
                  action: call-service
                  service: cover.set_cover_position
                  service_data:
                    position: 0
                    entity_id: cover.tapparella_della_camera
                show_icon: false
                card_mod:
                  style: |
                    ha-card {
                      --ha-card-background:
                      {% if is_state_attr('cover.tapparella_della_camera', 'current_position', 0) %}
                        green;
                        color: white;
                      {% endif %}
                styles:
                  card:
                    - border: 0px 0px 0px 0px
                    - border-radius: 0%
                    - box-shadow: 0px 0px 0px 0px
                tap_action:
                  service_data:
                    position: 50
                show_icon: false
                card_mod:
                  style: |
                    ha-card {
                      {% if is_state_attr('cover.tapparella_della_camera', 'current_position', 50) %}
                        green;
                        color: white;
                      {% endif %}
                styles:
                  card:
                    - border-radius: 0%
                tap_action:
                  service_data:
                    position: 100
                show_icon: false
                card_mod:
                  style: |
                    ha-card {
                      {% if is_state_attr('cover.tapparella_della_camera', 'current_position', 100) %}
                        green;
                        color: white;
                      {% endif %}
                styles:
                  card:
                    - border-radius: 0%
In order to get this tile card:
But I’d like to change the icon if the cover is in the following states (as example):
  • if it has a position <= 22%
  • if it has a position > 22% and != 50%
    -if it has a position == 50%
is there a chance to implement in the above code?
The simplest way is to create several tile cards with different icons and make visibility conditional on the position of the cover.
  1. Your posted code contains only a few lines related to the Tile card. If you wish to distract people - ok, otherwise post only a related code.
  2. Check if this cover entity changes it’s icon automatically dependently on a state. It is supposed to. If you need a different behavior - consider using:
    — either card-mod (discussed in a dedicated card-mod thread);
    — or config-template-card (or similar) (also discussed in dedicated thread).
