Hello all,
I just integrated the MySensors network from Domoticz, it works good but I have an issue when I send multiple commands at once (like turn off a group of lights). It is very intermitent, some respond some not, not the same every time. I suspect a timing issue. If I issue a command to the lights one by one it works flawlessly.
I saw in the documentation that we can change the optimistic value in the config, but I added the Mysensors via the GUI so I don’t know how to access the config, it does not appear in my configuration.yaml.
Any help or pointers are welcome,
Thank you!
