Hello, I have a template sensor based on MULTILINE EXAMPLE WITH AN IF TEST with 3 states displayed - ON, OFF and STBY, it works fine. But I need to show STBY only if measured value is lower than XX for at least 5 min.
Should I do it as automation or it may be within this sensor?
I am still beginner
This is my sensor:
sensors:
wm:
friendly_name: "WM"
value_template: >-
{% if states('sensor.amp') | float > 0.2 %}
ON
{% elif states('sensor.amp') | float < 0.2 %}
{% if states('sensor.amp') | float > 0 %}
STBY
{% else %}
OFF
{% endif %}
{% endif %}
it works, providing front end output based on telemetry period. Nonetheless I need to include a condition that value for STBY shall remain within given limit, ie. between 0.2 and 0 for 5 minutes at least.
Question is if it is possible to do it within “sensor” or should I create another “automation”
