Hi All:
FYI, I hope change system datetime in the hassio. i try used ntpd command or date command to change datetime ,but not success. if system datetime not sync my localtion,i cannot view log in home assisant web console.
It runs off NTP server and sync’ed to UTC. You need to define the timezone in config yaml file for local time.
Hi, I have tried your suggested method but no luck. Here the snippet from my yaml.
homeassistant:
latitude: -26.15
longitude: 28.03
elevation: 4500
unit_system: metric
time_zone: Africa/Johannesburg
