Hi all,
I have a question regarding the MQTT integration within hassio. I have setup the integration with my MQTT server (which runs on another server then Hassio) via the integration page. Works perfectly and my devices show up.
However; i would like to change this configuration (IP, username, password).
Question is: how?
I’m not able to find this MQTT configuration parameters anywhere. Not in the configuration.xml but also not on the integration MQTT page within Hassio. The only thing i can configure is auto discovery.
I’m running Hassio with Supervisor in Docker. Any help appreciated.
edit
Just found out that the configuration is stored in the “core.config_entries” file. Can i just edit this file with the new parameters? Is this the recommend method?
