How to change the pin mode, for example, I have defined an output pin, but want to change from output mode to input mode in the following code, how do I operate?
There are a few platforms for inputs but you can start here and tell us if something specific
You didn’t post any code.
on_turn_on:
- lambda: id(output_led_1).mode = "output"; # wishful code
on_turn_off:
- lambda: id(output_led_1).mode = "input"; # wishful code
Is there a way to change the pin mode from input to output in reaction to an event?
