How to change the source of mushroom card
Hi, with some of the last updates i have issue with mushroom card. I have two device on my Person (iphone and ipad) and till now every time i was tracking my Iphone and showing me where is my Iphone but not it is taking the info from my tablet. How can i change the source of the card (which now it it taking my tablet as source a) so it is taking the Iphone location ?
For example in the picture below it is showing that I am at home but I am not, only my tablet is there.
The source isn’t specific to the Mushroom card, it is attached to your person entity. The basic answer is go to Settings > People > Dimitar and remove the ipad from your person’s tracking devices otherwise it will continue being an issue not just for dashboard cards but also for automations that are conditional on presence.
Thanks, I’ve just removed Ipad from my person and disabled his device tracker entity because I have automations such as “turn on water heater when home/other zone is above 0 at specific time” and most of the time Ipad is at home and probably it will affect the correct behavior of the automation :slight_smile:
Just FYI, if you have “Allow person to login” checked for your person entity, any device you login in with as “Dimitar” will be automatically added to the tracking devices list. If you have devices that regularly stay home and you have the allow option checked, you should create a separate user to those devices.
