I think it should be assumed_state: false not assumed.state: false
@fxcoolby Thank you I edited that line
Developer > Check configuration > Ok and then reboot. But it still does not show the switch. Thank you, anyway
Hi after taking a closer look the config should be like following:
homeassistant:
customize:
switch.myuniquebulbid_1:
I think your mqtt unique_id serves as entity_id in ha unless it is not specified and it will pickup the name as entity_id.
Try above ans ee if it works.
