So far still getting set up, so using the default dashboard. When clicking the 3 little dots on a media player (google home speaker) There’s a small TTS field where I can send text to it to be spoken.
However, the default language seems to be english. How do I change the language for TTS on this popup?
Check here-
Also, check the language that you want to speak here by typing the language you want, then check if “talk” is supported.
Oh damn, I had looked at Text-to-Speech (TTS) - Home Assistant
No mention of language in config is mentioned here - only when using the service. I’ll try it out, thanks.
EDIT: It worked, thanks again.
