How to change value of Helper number at specific times?
I am looking for a way to automatically change the value of a Helper number at specific times of the day, knowing that these times could be different on week-ends. And ideally, I would like to be able to see the different values on a week view, like an agenda.
To give a bit of context, I want to store in a Helper the planned temperature for a room, and define the different values it can take along the day, and use it to set the thermostatic valve of the heater. For example, the dining room temperature could be 17°C during the night, 20°C during meals, and 18°C between meals. Automation will be used to cope with some events, for example when the window is open, the temperature is set to 4°C. And when the window is closed, I need to determine the temperature to which the thermostatic valve should be set, hence the need for the helper.
Thanks for reading, and sorry for the long text…
I don’t know of anything currently that would do that exactly… the closest option is likely the custom Scheduler component and Scheduler Card. There’s a good write-up at https://smarthomescene.com/guides/how-to-create-schedules-in-home-assistant/
Thanks, this component looks promising, I will test it.
