I am currently using a ESP32 which is connected to my RaspberryPi 4 via wifi. I am going to change my wifi so all my password and id will change. But only part of my code mentioning about wifi is this.
So this is for change directly the main code if I get it right. But if I change just the secrets won’t it be work? Because I actually doesn’t need my old infos.
If you update de device via USB , anything will work because wifi is not involved.
But if you update wirelessly, it will fail whenever it needs to connect to wifi and the actual wifi is still the old one.
Declaring the two networks seems the solution.
Here’s a little addition that worked for me. I managed to change the Wi-Fi settings by using the first method that PhilippeP described, with a little workaround:
First, I gave my guest Wi-Fi access to my network.
Then I entered the SSID and password of the guest Wi-Fi in ‘secrets’.
Clicked ‘update all’ in ESPHome.
Checked whether all the decices were connected to the guest Wi-Fi.
After that, I changed the password of my main Wi-Fi.
Then I updated the SSID and password in ‘secrets’ to the new settings.
And finally, I clicked ‘update all’ again.
For me, this worked perfectly on the first try.
(don’t forget to change back the guest Wi-Fi settings)
