Hi There,
Here’s what I got:
Logger: homeassistant.components.websocket_api.http.connection
Source: custom_components/zha_toolkit/znp.py:81
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 4:10:48 PM (1 occurrences)
Last logged: 4:10:48 PM
[547325846624] Error handling message: Unknown error
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 27, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 534, in handle_execute_script
await script_obj.async_run(msg.get("variables"), context=context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1253, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 354, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 372, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 575, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1630, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1667, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/config/custom_components/zha_toolkit/__init__.py", line 535, in toolkit_service
raise handler_exception
File "/config/custom_components/zha_toolkit/__init__.py", line 499, in toolkit_service
await handler(
File "/config/custom_components/zha_toolkit/__init__.py", line 582, in command_handler_default
await default.default(
File "/config/custom_components/zha_toolkit/default.py", line 33, in default
await handler(app, listener, ieee, cmd, data, service, params, event_data)
File "/config/custom_components/zha_toolkit/znp.py", line 81, in znp_restore
await znp_backup(app, listener, ieee, cmd, current_datetime, service)
TypeError: znp_backup() missing 2 required positional arguments: 'params' and 'event_data'
I guess the last line is important? However I don’t get the option to fill anything in when using the restore.
I did redownload the integration and that yielded the same result.
