How do I run hass check_config script on hassio ssh terminal?
ha core check
I get this…
Our Cli:
$ hassio help
~ $ ha core check
-bash: ha: command not found
Hmm. I don’t run that installation method so I’m not sure but seeing “hassio” there makes me think you’re on an older version. Try hassio ha check
Running hassio help
as suggested in the prompt would be a good first step btw
Thanks! Got this, so this is an old version of hassio? Oh cause i can update homeassistant from my lovelace but not hassos. I just found this to update (https://www.home-assistant.io/blog/2019/12/17/hassos-release-3/):
~ $ hassio info
arch: armv7
channel: stable
docker: 19.03.5
hassos: "3.12"
homeassistant: 0.110.4
hostname: hassio
logging: info
machine: raspberrypi2
supervisor: "227"
supported_arch:
- armv7
- armhf
