How to check disk usage in HASSIO?
Hello. My HASSIO HA shows that about 6GB of my disk is full. But when I ssh as root to Raspberry and issue command du -d 1 -h, I see this:
0	./sys
96.0K	./media
0	./dev
4.7M	./lib
158.8M	./usr
4.0K	./mnt
4.0K	./home
224.0K	./run
16.0K	./tmp
0	./proc
4.0K	./srv
80.0K	./var
7.7M	./bin
16.0K	./root
4.0K	./opt
80.0K	./sbin
2.1M	./etc
4.0K	./addons
483.2M	./backup
4.0K	./share
4.0K	./ssl
56.0K	./data
683.3M	./config
112.0K	./libexec
1.3G	.
Total? 1,3GB. How can I see remaining files that take 4,5GB? It is most probably InfluxDB, but I would like to be able to do proper directory usage analysis. Best would be access to all files and command ncdu.
I’m seeing the same issue on mine. I am assuming that the InfluxDB is also the issue, but haven’t seen a way to find the space used on it.
My assumption is that the InfluxDB is running in a Docker container and as such is stored differently, but I don’t know enough about it to know for sure, let alone where to look next.
Did you ever find a solution to this?
