dbrunt
(Daniel)
November 17, 2020, 5:19am
1
I want to test if ‘00:21:CC:0A:35:DF’ is found in sensor.vog_l04_bluetooth_connection
connected_paired_devices
. The state attributes are:
connected_not_paired_devices: '[]'
connected_paired_devices: '[AC:E3:42:71:9E:E9]'
paired_devices: >-
[E0:7D:EA:42:D1:07, 40:16:3B:AD:9A:BD, C2:BB:9F:89:01:45, AC:E3:42:71:9E:E9,
C4:A2:60:01:85:76, D4:81:CA:F0:A1:CA, 08:EF:3B:24:2E:C7, C9:C1:54:1B:88:C4,
90:F1:AA:F9:36:AB, 00:23:11:00:00:20, 00:21:CC:0A:35:DF, 1C:12:B0:B4:DE:89,
00:23:15:00:3C:AA]
unit_of_measurement: connection(s)
friendly_name: VOG-L04 Bluetooth Connection
icon: 'mdi:bluetooth'
The BT device I am checking for is not currently connected.
This template in dev tools returned the element to examine:
{{ state_attr('sensor.vog_l04_bluetooth_connection','connected_paired_devices') }}
Then I added testing for string equality:
{% if is_state_attr('sensor.vog_l04_bluetooth_connection','connected_paired_devices','[AC:E3:42:71:9E:E9]') %}
true
{% endif %}
and it returned True.
What’s the next step to return true/false if the list contains ‘00:21:CC:0A:35:DF’ ?
Thanks.
dbrunt
(Daniel)
November 17, 2020, 5:55am
2
I continued searching, reading, testing and came up with this:
{% set bt_devices = state_attr('sensor.vog_l04_bluetooth_connection', 'connected_paired_devices').split(',') %}
{% for device in bt_devices %}
{% if device == '[00:21:CC:0A:35:DF]' %}
true
{% else %}
false
{% endif %}
{% endfor %}
Would there be another shorter method?
tom_l
November 17, 2020, 6:22am
3
This will return true if the address is in the list/string:
"{{ '00:21:CC:0A:35:DF' in state_attr('sensor.vog_l04_bluetooth_connection','connected_paired_devices') }}"
dbrunt
(Daniel)
November 17, 2020, 8:51am
4
Thank you so much! I knew there had to be a better way than what I lashed together!!
That’ll complete my automation to open garage door/unlock front door…
alias: Daniel arrives home
description: ''
- platform: state
entity_id: person.daniel_brunt
to: home
condition: []
- service: alarm_control_panel.alarm_disarm
data: {}
entity_id: alarm_control_panel.alexa_guard_da03a
- choose:
- conditions:
- type: is_plugged_in
condition: device
device_id: 52fa40cb8ef749a1a7800d6495551219
entity_id: binary_sensor.vog_l04_is_charging
domain: binary_sensor
- condition: or
conditions:
- condition: template
value_template: >-
sequence:
- type: toggle
device_id: b6b8158202d211eba4bc95be153ab261
entity_id: switch.mimolite_switch
domain: switch
- wait_for_trigger:
- type: not_plugged_in
platform: device
value_template: >-
"{{ '00:21:CC:0A:35:DF' not in
timeout: '01:00'
continue_on_timeout: false
- type: toggle
domain: switch
- conditions:
- type: is_not_plugged_in
condition: device
sequence:
- choose:
- conditions:
- condition: state
entity_id: sun.sun
state: below_horizon
sequence:
- type: turn_on
device_id: b6b7e97b02d211ebb345b1a87b2c5b26
entity_id: switch.nzw30_smart_switch_switch
domain: switch
default: []
- service: logbook.log
name: Daniel Arrives Home
message: Wait for motion trigger...
domain: automation
entity_id: binary_sensor.lumi_lumi_sensor_motion_aq2_a2154d04_ias_zone
- wait_for_trigger:
- type: motion
platform: device
device_id: ad660333093c11ebaadee17e5246204a
timeout: '00:05:00'
message: 'Motion detected, unlock front door'
domain: automation
- device_id: b6f24cd502d211ebb38ba1e9f8bad99f
domain: lock
entity_id: lock.zm1701_electronic_deadbolt_door_lock
type: unlock
default: []
mode: single
