How to check if a sensor from home assistant has value "unknown"
I would like to check if the status returned by a sensor implemented in home assistant is “unknown”
I’ve the following configuration
  • The sensor is updated through native API
  • The sensor is created in ESPHome using the platform home assistant
  - platform: homeassistant
    entity_id: sensor.sleeptime
to check the value I’ve implemented the following code:
    - lambda: |-
       if(id(sleeptime).state == "unknown")
            id(deep_sleep_23).set_sleep_duration(1000);
       else
          id(deep_sleep_23).set_sleep_duration(id(sleeptime).state*1000);
but during the compiling I get the error shown in the image
I know that the problem is due to the compare because is not possible to compare a float variable with a const char.
Do you know how could check if the status value is different from “unknown”?
I solved with function isnan in this way:
    - lambda: |-
       if(isnan(id(sleeptime).state))
       else
