The difference between ‘plus’ and ‘none plus’ is the expiration of a patent where it infringed the patent if when the device was switched, it told anybody imediately, so it will update, just not quickly (these are ‘none plus’ devices).
You got round this by polling the device
Polling is bad, try to avoid where possible
Where you NEED full update then set the polling as low (less frequently) as you can (less traffic)
@Rakaandro
To check what is what for a device.
Go to the Z-wave configuration page - select the node concerned - then click node info - if its plus then ‘is z-wave plus’ will be true
Caution: I have 3 z-wave hub sticks (1 aeotec, 2 everspring) all are plus but info says they aren’t
Also (as freshcoast says) a secure message takes 4 message blocks, a none secure takes just 1
I recommend using secure only for devices that ‘require’ it. ie some locks
