First off all, I feel dumb.
I’m not a database expert, but still…
I installed the InfluxDB add-on with default config, created a home_assistant db in it en added influxdb: (without options) to the configuration yaml and restarted.
I could not find any error, so I guess all is okay:-)
But how do I check that HA data is flowing into the InFluxDB home_assistant database, because the next step is to use Grafana and I need to be sure that the integration is working before I go on…
