So I am a bit of a newbie with home assistant, & in turn A virgin with templates, variable & Blueprints.
This is my first attempt at creating a Blueprint & so I started with A script that I have tried to convert to a Blueprint. But for the sake of simplicity, I can’t work out how to get the On/Off state of the lights in A room(area) to register? (from a Target Selector for lights) So with the great words from Pablo Picasso, i have obtained idea’s, concepts & code from other sources, but I just can’t get it to work.
I think it should be done with a variable & template like:
input:
target_lights:
description: The Lights this Script is Targeted at.
selector:
entity:
domain: light
variables:
lights: !input "target_lights"
- condition:
- "{{ expand(lights) | selectattr('state', '==', 'on') | list | count > 0 }}"
I’m assuming it is how I am referencing the variable or implementing the template,
but I have been banging my head for the last 24hrs on this & i’m stuck…
So Rumpelstiltskin, I offer you my first born blueprint to HAss:
blueprint:
name: Another Light Blueprint-Script
description: "My Default Light Blueprint-Script with my take on Profiles;\n\
\ - Bright. - (For Day time & Events, I need to be Awake; Bright eyed & bushy tailed).\n\
\ - Dimmed - (For after sunset & before sunrise when i'm (still) thinking about bed,\
\ but I will want to be able to read the Funny pages).\n\
\ - Night-Light - (For bed/sleep time, & you don't want to wake
\ everyone else up, but you still want to see in an emergency; how to get to the Fridge)\n\
\ - Colour-Loop - (Was to be Aurora-Australis, but color-loop is easier to remember).\n\
\ - Circadian - (For the rest of the house at night, & to get everyone in sync @ night with you).\n\
\ - Adaptive - (This works really well with a bed/sleep input_boolean).\n\
\ - Random - (A Sorely missed replacement to the light effect).\n\
\ - Custom - (Utilise this when using scenes & applying custom colour effects).\n\
\ - Flash - (works great in conjunction with Alarm Panel Automations).\n\n\
\ - A PREREQUISITE of an input_select { Dropdown } with the desired above Profile/s (words) added is required. \n\
\ - A PREREQUISITE of an input_boolean { Toggle } is reqired for Adaptive Profile Night-Light to work.\n\
\ Go to Settings > Devices & Services > Helpers > Create Helper > { Dropdown } or { Toggle }.\n
\ & I'm assuming you already have some Lights that you wanted to add.\n\n\
\ Designed to be used with A Automation-Script, & that decides IF & WHEN too turn the Light/s On\
\ (by calling this script) & Off (by any means you see fit)."
domain: script
input:
target_lights:
selector:
entity:
domain: light
profile_input_select:
name: Profile input_select (Dropdown)
description: The Profile the Targeted Light/s will comform to.
selector:
entity:
domain: input_select
profile_adaptive_input_switch:
name: Profile - Adaptive - input_boolean (Toggle)
description: The Light.Turn_On Adaptive Profile Night-Light Time Switch.
selector:
entity:
domain: input_boolean
transition_on:
name: Turn On Light Transition Time
description: The Light.Turn_On Transition Time.
default: 0
selector:
number:
min: 0.0
max: 300.0
mode: slider
step: 1.0
transition_change:
name: Change Light Transition Time
description: The Light.Turn_On Transition Time, when one or more light/s are already on.
default: 9
selector:
number:
min: 0.0
max: 300.0
mode: slider
step: 1.0
profile_colour_loop_transition_time:
name: Profile - Colour Loop - Transition Time
description: The Colour Loop Profile Light.Turn_On Transition Time between colours.
default: 3
selector:
number:
min: 1.0
max: 300.0
mode: slider
step: 1.0
profile_circadian_bed_time:
name: Profile - Circadian - Bed Time
description: The Circadian Profile Night-Light Time.
default: '22:30:00'
selector:
time:
profile_circadian_wake_up_time:
name: Profile - Circadian - Wake Up Time
description: The Circadian Profile Wake Up Time.
default: '6:30:00'
selector:
time:
sun_before_offset:
name: Sunrise - Offset
description: Offset the sunrise time.
default: '1:00:00'
selector:
time:
sun_after_offset:
name: Sunset - Offset
description: Offset the sunset time.
default: '-1:00:00'
selector:
time:
profile_bright_color_temp:
name: Profile - Bright - Colour Tempature
description: The Bright Profile light Colour-Tempature.
default: 153
selector:
color_temp:
profile_bright_brightness:
name: Profile - Bright - brightness
description: The Bright Profile light brightness.
default: 255
selector:
number:
min: 0.0
max: 255.0
mode: slider
step: 1.0
profile_dimmed_color_temp:
name: Profile - Dimmed - Colour Tempature
description: The Dimmed Profile light Colour-Tempature.
default: 500
selector:
color_temp:
profile_dimmed_brightness:
name: Profile - Dimmed - Brightness
description: The Dimmed Profile light brightness.
default: 175
selector:
number:
min: 0.0
max: 255.0
mode: slider
step: 1.0
profile_night_light_color_temp:
name: Profile - Night Light - Colour Tempature
description: The Night Light Profile light Colour-Tempature.
default: 500
selector:
color_temp:
profile_night_light_brightness:
name: Profile - Night Light - Brightness
description: The Night Light Profile light brightness.
default: 25
selector:
number:
min: 0.0
max: 255.0
mode: slider
step: 1.0
variables:
sequence:
- choose:
- conditions:
- condition: state
entity_id: !input profile_input_select
state: Bright
sequence:
- if:
- condition:
then:
- service: light.turn_on
color_temp: !input profile_bright_color_temp
brightness: !input profile_bright_brightness
transition: !input transition_change
!input target_lights
else:
transition: !input transition_on
- conditions:
- condition: state
state: Dimmed
sequence:
- if:
- condition: template
value_template: >-
{{ expand(lights.entity_id) | selectattr('state', '==', 'on') | list | count > 0 }}
then:
color_temp: !input profile_dimmed_color_temp
brightness: !input profile_dimmed_brightness
else:
- conditions:
- condition: state
state: Night-Light
sequence:
- if:
value_template: >-
{{ is_state( 'lights' , 'on') }}
then:
color_temp: !input profile_night_light_color_temp
brightness: !input profile_night_light_brightness
else:
- conditions:
- condition: state
state: Random
sequence:
- if:
value_template: >-
then:
hs_color:
- "{{ range(360)|random }}"
- 100
else:
hs_color:
- 100
- conditions:
- condition: state
state: Colour-Loop
sequence:
hs_color:
- 100
brightness_pct: 100
transition: !input profile_colour_loop_transition_time
- repeat:
while:
value_template: "{{ expand(lights.entity_id) | selectattr('state', '==', 'on') | list | count > 0 }}"
- condition: state
state: Colour-Loop
sequence:
hs_color:
- 100
brightness_pct: 100
- delay:
hours: 0
minutes: 0
seconds: !input profile_colour_loop_transition_time
milliseconds: 0
- conditions:
- condition: state
state: Flash
sequence:
- repeat:
while:
- condition: state
state: Flash
sequence:
flash: short
- delay:
hours: 0
minutes: 0
seconds: 3
milliseconds: 0
- conditions:
- condition: state
state: Circadian
sequence:
- choose:
- conditions:
- condition: time
after: !input profile_circadian_bed_time
before: !input profile_circadian_wake_up_time
sequence:
- if:
value_template: >-
then:
else:
- conditions:
- condition: sun
before: sunset
after: sunrise
before_offset: !input sun_before_offset
after_offset: !input sun_after_offset
sequence:
- if:
value_template: >-
then:
else:
default:
- if:
value_template: >-
then:
else:
- conditions:
- condition: state
state: Adaptive
sequence:
- choose:
- conditions:
- condition: state
entity_id: !input profile_adaptive_input_switch
state: "on"
sequence:
- if:
value_template: >-
then:
else:
- conditions:
- condition: sun
before: sunset
after: sunrise
sequence:
- if:
value_template: >-
then:
else:
default:
- if:
value_template: >-
then:
else:
default:
- if:
- condition:
- "{{ expand(lights.entity_id) | selectattr('state', '==', 'on') | list | count > 0 }}"
then:
else:
I hope someone out there can help me with this PLEASE???
There is a much better way of doing this:
