ayandon
(Ayan Debnath)
July 6, 2021, 8:01am
1
I am very very new to Home Assistant and Node-Red.
I have a Home Assistant Addon - Hassio Hostapd Extended
In Node-Red, I want to check the current status (running or stopped) of this addon.
How to do it in Node-Red?
Mikefila
(Mike Fila)
July 9, 2021, 2:34am
3
You need to make a rest sensor.
This is how I check if letsdnsocloud is running :
sensor :
# letsdnsocloud
- platform: rest
resource: https://home.mydomain.com:8123/api/hassio/addons/3983e8d8_letsdnsocloud/info
value_template: '{{ value_json.data.state }}'
scan_interval:
minutes: 10
headers:
Authoβ¦
ayandon
(Ayan Debnath)
July 9, 2021, 8:57am
4
Thanks a lot for the tip.
And which node should I use to check in Node-RED?
Mikefila
(Mike Fila)
July 11, 2021, 6:03pm
5
Like any other sensor. You could use it in a events current state node. It will output when the sensor changes. Connect to call service node and define the action.
SVNKoch
(Sven Koch)
October 20, 2022, 9:26am
6
For anyone stumbling across this like me:
Nowadays there is a binary sensor which can tell you if an addon is running. You just have to enable it.
Go to Settings > Devices > Addon in question > Sensors > Running
> Advanced Options > Enable.
Using the not_running
trigger you can trigger on an addon stopping.
Feature was added here:
home-assistant:dev
β home-assistant:addon-started
opened 05:19PM - 20 Oct 21 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N⦠OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
![image](https://user-images.githubusercontent.com/15093472/138140777-9c06d98e-3f08-4a4f-9c6a-e069e8be586b.png)
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [ ] No score or internal
- [ ] π₯ Silver
- [ ] π₯ Gold
- [ ] π Platinum
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
