paisitw
(Little Boy)
March 6, 2023, 8:43am
1
Hi, I have installed HA with Home Assistant Operating System approach on pi4, 128GB SD card. My recorder is set at 10 days. I configured some backup and store only one copy on local and the rest to Google drive.
Recently I got warning about usable space is low (<10GB), I have no idea what eat up my space the most. I checked my log and only a few MB used. Is there a way to check the usage detail?
I would start with installing add on Samba, FTP or terminal and check the folder sizes, so you can see where the storage is being consumed. You can also install the system sensors, but that is just to alert, not to solve the issue.
System Monitor - Home Assistant (home-assistant.io)
paisitw
(Little Boy)
March 7, 2023, 9:02am
3
I have those installed. However I did check on each folder, not found any suspicious. I wonder I can check add-on stuff which is installed on separate container. Those one I don’t have visibility. 128GB SD card is big considered 10 days retention and one backup copy though.
you can do a full backup, and then export the file, to see what addon is eating
i use portainer addon to clean up old images left
paisitw
(Little Boy)
March 7, 2023, 9:22am
5
Good idea. Let me try. By the way did add-on portainer work in HA in your case? I tried it last year but no luck.
yeah, i still have it, but seems deprecated now
I agree with the use of system monitor inside your config just add:
- platform: systemmonitor
resources:
- type: disk_use_percent
arg: /
arg: /config
- type: disk_use
arg: /
- type: disk_free
arg: /
- type: memory_free
- type: memory_use
- type: memory_use_percent
- type: load_1m
- type: load_5m
- type: load_15m
- type: processor_use
- type: last_boot
use swiss army knife (hacs frontend?) to display with
title: Power
path: sake7
panel: false
theme: 'NM - Dark Steelblue'
cards:
- type: vertical-stack
cards:
- type: custom:decluttering-card
template: header_template
variables:
- content: 'Servers'
variables:
- content: 'HASS IO'
- font_color: var(--secondary-text-color)
- font_size: 3em
- type: horizontal-stack
cards:
# Multiple circles with system cpu monitoring. NIce for easy CPU changes in graph
- type: 'custom:swiss-army-knife-card'
entities:
# Memory
- entity: sensor.memory_use_percent
decimals: 0
area: 'Main Server'
icon: mdi:memory
# Disk
- entity: sensor.disk_use_percent
decimals: 0
icon: mdi:harddisk
# CPU
- entity: sensor.processor_use
decimals: 0
# System Load
- entity: sensor.load_1m
decimals: 2
unit: '1m'
- entity: sensor.load_5m
decimals: 2
unit: '5m'
- entity: sensor.load_15m
decimals: 2
unit: '15m'
# Disk
decimals: 0
icon: mdi:harddisk
- entity: sensor.disk_free
decimals: 0
icon: mdi:harddisk
# Memory
decimals: 0
icon: mdi:memory
- entity: sensor.memory_free
decimals: 0
icon: mdi:memory
# Developer settings. Should be removed in production
dev:
debug: false
ts: true
performance: false
# Set relative x/y aspectratio: twice as wide as it is high
aspectratio: 2/1
# Define the layout of the card
layout:
# Define global card styles.
# The card gets a Neumorphic overall filter, which only works on the 1st level
# of SVG objects it sees. As a result these objects morph visually into single
# objects if they are (partially) drawn over each other.
# The Used/Free rectangle and disk free percentage segmented arc are an example
# of this: the segmented arc is partially drawn on top of the rectangle.
styles:
card:
toolsets:
filter: url(#nm-1)
# Finally, the toolsets definitions
toolsets:
- toolset: memory-free-used
position:
cx: 35
cy: 74
tools:
- type: rectex
position:
cx: 50
cy: 50
width: 60
height: 20
radius:
all: 2
# Used
- type: name
position:
cx: 25
cy: 45
entity_index: 8
# Define css style of the name tool.
# Each part of the tool has its own style definition. For single part tools
# like the 'name' tool, the style definition equals the tool type.
# For multi-part tools, each part has its own style definition.
styles:
name:
font-size: 5.0em
text-anchor: start
- type: state
position:
cx: 63
cy: 45
entity_index: 8
styles:
state:
font-size: 6em
font-weight: 700
text-anchor: end
# Free
- type: name
position:
cx: 25
cy: 55
entity_index: 9
styles:
name:
font-size: 5em
text-anchor: start
- type: state
position:
cx: 63
cy: 55
entity_index: 9
styles:
state:
font-size: 6em
font-weight: 700
text-anchor: end
- toolset: memory
# Use pre-defined template for this part.
# Template has variables.
template:
variables:
- entity: 0
- show_scale: false
position:
cx: 72.5
cy: 74
# Scale to 80% of toolset template.
scale: .8
# Overwrite template with the following configuration not covered by the template
# variables. id is required to make this work. So much possibilities...
tools:
- type: segarc
show:
scale: true
style: 'colorstops'
segments:
colorstops:
gap: 1
# arc can be 'followcolorstop', or 'followvalue'
arc_color: 'followcolorstop'
colors:
00: 'DarkSeaGreen'
70: 'yellow'
80: 'orange'
90: 'red'
- toolset: areatoolset
position:
cx: 195
cy: 95
scale: 1
tools:
# Areas 0 refers to the first entity in the list, ie index 0
- type: area
entity_index: 0
position:
cx: 50
cy: 50
styles:
area:
font-size: 6em
text-anchor: end
- toolset: disc-free-used
position:
cx: 35
cy: 26
tools:
- type: rectex
position:
cx: 50
cy: 50
width: 60
height: 20
radius:
all: 2
# Used
- type: name
position:
cx: 25
cy: 45
entity_index: 6
styles:
name:
font-size: 5em
text-anchor: start
- type: state
position:
cx: 63
cy: 45
entity_index: 6
styles:
state:
font-size: 6em
font-weight: 700
text-anchor: end
# Free
- type: name
position:
cx: 25
cy: 55
entity_index: 7
styles:
name:
font-size: 5em
text-anchor: start
- type: state
position:
cx: 63
cy: 55
entity_index: 7
styles:
state:
font-size: 6em
font-weight: 700
text-anchor: end
- toolset: disc
template:
variables:
- entity: 1
- show_scale: true
position:
cx: 72.5
cy: 26
scale: .8
tools:
- type: segarc
show:
scale: true
style: 'colorstops'
segments:
colorstops:
gap: 1
colors:
00: 'DarkSeaGreen'
70: 'yellow'
80: 'orange'
90: 'red'
- toolset: cpu
template:
variables:
- entity: 2
- show_scale: true
position:
cx: 127.50
cy: 50
scale: 1
tools:
- type: segarc
show:
scale: true
style: 'colorstops'
lastcolor: true
segments:
colorstops:
gap: 1
colors:
00: '#FFF6E3'
10: '#FFE9B9'
15: '#FFDA8A'
20: '#FFCB5B'
22.5: '#FFBF37'
25: '#ffb414'
60: '#FFAD12'
70: '#FFA40E'
80: '#FF9C0B'
90: '#FF8C06'
- toolset: load1m
template:
variables:
- entity: 3
- show_scale: false
position:
cx: 165
cy: 22.5
scale: .7
tools:
- type: segarc
show:
style: 'colorlist'
scale:
min: 0
max: 2
segments:
colorlist:
gap: 1
colors:
- '#FFE9B9'
- '#FFCB5B'
- '#ffb414'
- '#FFA40E'
- '#FF8C06'
- toolset: load5m
template:
variables:
- entity: 4
- show_scale: false
position:
cx: 171
cy: 58
scale: .6
tools:
- type: segarc
show:
style: 'colorlist'
scale:
min: 0
max: 2
segments:
colorlist:
gap: 1
colors:
- '#FFE9B9'
- '#FFCB5B'
- '#ffb414'
- '#FFA40E'
- '#FF8C06'
- toolset: load15m
template:
variables:
- entity: 5
- show_scale: false
position:
cx: 152.5
cy: 82.5
scale: .5
tools:
- type: segarc
show:
style: 'colorlist'
scale:
min: 0
max: 2
segments:
colorlist:
gap: 1
colors:
- '#FFE9B9'
- '#FFCB5B'
- '#ffb414'
- '#FFA40E'
- '#FF8C06'
i used their template and just added sensors. you may have to change a little bit around if you use this but i think they have a great gui here
lordvalium
(Lordvalium)
December 29, 2023, 6:34pm
8
how did you set the recorder “at 10 days” ?
Dont know how to read the howto Recorder - Home Assistant
BartGysens
(Bart Gysens)
February 1, 2024, 9:58am
9
No longer supported.
The System Monitor YAML configuration is removed
This no longer works in version 2024.7.0. Please adjust before upgrading.
Configuring System Monitor using YAML is removed.
Your existing YAML configuration is automatically imported into the UI.
Remove the systemmonitor configuration from your configuration.yaml file and restart Home Assistant to resolve this issue.
Use “sensor.system_monitor_… ”
mikeybatoz
(Mikeybatoz)
February 8, 2024, 12:42pm
10
does the glances integration still work?
