How to check when script was last triggered? I’m trying to use with motion sensor to check when last called. The motion sensor is connected to the alexa app and it is calling the script.
That information can be obtained using a template: {{state_attr('script.XXXX','last_triggered')}}
If you need help incorporating templating into your automation you will need to post the automation.
Would it be possible to have a condition checking how long it had been?
motion_bedroom:
alias: Motion bedroom
sequence:
- choose:
- conditions:
- condition: time
after: '17:00:00'
before: '23:00:00'
weekday:
- mon
- wed
- tue
- thu
- fri
- sat
- sun
sequence:
- service: scene.turn_on
entity_id: scene.bedroom_on
metadata: {}
default: []
mode: single
icon: mdi:motion-sensor
Yes, you can use templates to compare the current time to the last_triggered
time. For example, if you wanted to allow a script to be executed only if it hadn’t been triggered for at least 5 minutes you would use:
condition: template
value_template: >
{{now() >= state_attr('script.XXX','last_triggered')|as_local +
timedelta(minutes=5) }}
I tried it but it didn’t work. Am I doing something wrong?
sequence:
- choose:
- conditions:
- condition: time
after: '18:00:00'
before: '23:00:00'
weekday:
- mon
- wed
- tue
- thu
- fri
- sat
- sun
- condition: template
value_template: >
{{now() >=
state_attr('script.motion_bedroom','last_triggered')|as_local +
timedelta(minutes=1) }}
sequence:
metadata: {}
default: []
mode: single
We’re going to need a little more information…
What do you mean when you say you tried it?
What happened?
Is it between 17:00 and 23:00 where you are in the world?
What does the script trace/debug say?
I ran the script with and without the template. Without it worked. When I added the template it broke. Yes it is between the times however it is still not working. This is my debug:
Executed: 5 April 2022, 21:08:05
Result:
result: false
conditions/0
Result:
after:
__type: <class 'datetime.time'>
isoformat: '18:00:00'
now_time:
isoformat: '21:08:05.016353'
before:
isoformat: '23:00:00'
weekday:
- mon
- wed
- tue
- thu
- fri
- sat
- sun
now_weekday: tue
result: true
conditions/1
Result:
result: false
entities:
- script.motion_bedroom
This is never going to do anything. last_triggered
is set to the current date and time when the script starts running. Your script basically says this:
IF time is between 18:00:00 and 23:00:00 AND it's been 1 minute since this started
Turn on a scene
It’s not possible for that to do anything unless it somehow took a full minute to check the time.
Do you want the script to wait 1 minute before turning on the scene after the motion sensor detects motion? If so what you’re looking for is a delay
action like this:
sequence:
- choose:
- conditions:
- condition: time
after: '18:00:00'
before: '23:00:00'
sequence:
- delay: '00:01'
metadata: {}
default: []
mode: single
Note: I dropped the weekday
bit because every day is the default, you only need to list if if you want it to pass on a subset of the days of the week
If this isn’t what you want then perhaps you can tell us what you’re trying to do? Would be easier to help
Is it possible to do if the script hasn’t been run for at least 1 minute then run script?
Never mind I figured it out. I created a script which turns on a scene (scenes don’t have the last triggered attribute) I then made another script with the timings and then used this.
condition: template
value_template: >
timedelta(minutes=4) }}
This turns on the light on script if it hasn’t been 4 minutes.
