Hello, I’m considering options of temperature control in the house where I have multiple radiators and a boiler which can set the temperature of the water in pipes. I am new at this topic so any silly mistakes are possible. I intend to be able to control each room separately but at the same time keep the boiler on only when it’s needed. Also, I don’t need to keep the temperature in the pipes always the same.
So, I bought a few Devolo TRV (valves) already. They have Z-wave and can feed HA back about the temperature, and they are cheap. I believe my way to go is to have more of them or other z-wave/zigbee based TRVs. Here’s everything mostly simple: if the temperature is less than desired - open the valve. If there’s a window open - shut all the valves. Switch it on if somebody in the room for a while. And so on. This task I would love to outsource to HA automations. I like the automation format. However, I’m would love to know just one thing. Can my TRVs be closed completely and opened completely from HA? I suppose even if there’s no direct command then I can set the temperature to minimal to close and maximum to open.
Next, I’m going to buy a smart thermostat which I would love to manage from the HA. It should be able to switch on and off the boiler and set the temperature to certain ranges. I don’t want to control it continuously like to set 45° here, and then 44° in a minute, etc… I think it’s easier to automate to set 75° to warm the house quickly once we get home, then keep 60°-65° during active hours, and set let’s say 45° during the night.
I see a few problems here. First of them is the thermostat itself. There are many options but none of them looks exactly as I desire. I’m not talking about “exterior”. I cannot figure out how exactly it should operate. I find Plugwise as a very promising option. However, due to lack of knowledge in HA, I don’t know would it be possible to achieve with that integration. Second, if this is a thermostat then it has its own temperature sensor and will try maintaining a temperature at the set level. Basically, I want the thermostat to be smart in terms of connectivity and dumb when it gets working as a separate unit.
I can let HA be the heart of this because I cannot see why anything else would be more reliable. All other options are either vendor locked or too expensive. I considered Tado, Honeywell Evohome, and other vendor-based solutions. Do I miss something?
Hi, I have the same difficulty finding a thermostat. It should be able to connect with HA via wifi or ethernet (read and set temperature). When heat is needed, the thermostat should use opentherm to get the heater going. My family will use HA to set the temperature per room via the programmable radiator knobs (zwave). When the server is not functioning the temperature setting should be manually controllable (emergency fallback).
Oh, and the thermostat shall not ‘call home’ to an external website. Data stays in the house.
Hi Maarten,
It turns out that almost any thermostat can do that with one little exception: all the communications go via otgw. this piece of electronics is actually small thermostat on its own. fully passive but still a one. otgw can work in two modes.
first is just scrapping the communication messages between the boiler and the thermostat. from these messages you can find out what are the values of most of the HVAC parameters here like water temperature or heating set point. otgw software kindly parses the messages for you so don’t need to hassle with all these opentherm protocol stuff.
the second one is actually a gateway. in this mode you’re make two other fooled because the boiler and the thermostat think that nothing changes. however, otgw substitute the original messages from thermostat to the boiler with those you set in otgw monitor (app on windows).
then you have your HA. it works as otgw monitor. so you can say to otgw to work in override mode (substituting commands in the message exchange) from HA. I’m not sure does otgw switch to the monitor mode when a server is down but it would be really nice if it does. If you can figure out this question with positive result it would actually solve your problem in a way you want.
After a few days of testing, I put my otgw in always override mode setting up heating set point to the temperature I desire for each part of the day.
A few tips along the way.
You can switch off water heating if you set heating setpoint to 10°C.
You can disable the override mode by setting a heating setpoint to 0. So that your thermostat will control the boiler.
Hope it helps. If not I would be happy to answer your further questions.
thermostat Opentherm Anna 24V/OT PLUGWISE
All bought at ROBBshop in the Netherlands.
I already had a Aeotec z-wave USB stick, which I coupled to a Raspberry Pi 4b board using a USB hub. (The hub is needed due to an error in the USB port of the Pi board.)
Note: the valves are not re-transmitting in the z-wave mesh. You need intermediate z-wave devices (like a Fibaro wall plug) for radiator valves located far from the Raspberry with Aeotic stick.
The Anna thermostat comes with two parts: a thermostat with screen for in the living room. This one is connected via the 2-wire cable to the interface part, which you place next to your opentherm-compatible heater. Easy to connect with one screw-driver.
Home Assistant can talk to the Anna interface and you can read and set the temperatures on all devices. If somehow Home Assistant is not working, I can still control all devices manually by pressing buttons.
Plugwise is the most privacy friendly thermostat I could find.
Before a winter season started, a little update on the topic. OTGW NodeMCU version seems to be working after the winter of testing. Most of the functions you will figure out how to set up, even if it can be clumsy or quirky (based on your boiler). There are some problems you will get with integrity to HA (like that having many state changes in HA but the real-life state isn’t changed) but in general, it’s pretty good.
As a solution, it can be to use HA addon otmonitor
Another project you might have to consider if you’re willing to have more control over your boiler is this arduino/esp based project:
I have no clue what are the strong and weak points of this project.
How are your experiences with the Z-Wave Spirit Eurotronics? I’m also using an Anna and I’m looking for compatible radiator valves. Can you also share us a bit about your config/automation that links the Anna and the valves with HA?
my experience with the Z-Wave Spirit Eurotronics radiator valves:
one of the 9 devices does not read back the temperature anymore. Instead of sending it back to the shop, I switched it to a location where that is not important. I am still able to set temperature.
The first batteries had to be replaced after approx. 8 months. You hear the valve turning now and then due to changing room temperatures. That takes some energy.
My HA (on Pi4) crashes regularly due to SD card corruption. These z-wave valves produce a lot of log entries. I am fed up with unstable HA and am trying to migrate to a virtual machine on my CentOS 6 server. Unfortunately I have UEFI boot issues (off-topic).
Thanks for sharing! Good to hear that these valves work out mostly.
How do you regulate room temperatures (turn on radiator valves in seperate rooms) vs temperature readings of Anna, which is probably in your living room?
Do you run a seperate script to control your central heater? Or can you integrate the radiator valves in the Anna software somehow?
I was not working on that yet. In principle you could read out the temperature from each location and act on that by setting a new temperature to Anna.
My primary reason for installing this system is for when I am using the woodburner in the living room. My family members have cold rooms. They are able to set the temperature from their computer. In practice, they set the radiator temperature by hand.
The central heater is only controlled by HA and of course manually. Radiator valves can not be integrated in the Anna box, but of course HA is capable of that.
I have the ZigBee version of these and I use them with HA acting as the thermostat and a simple on/off tasmota relay on the boiler. Works pretty well with some simple logic on the automations. At the moment I’m only missing being able to regulate tap water temperature and have bought the ihormelnyk.com esp shield. I’m yet to look at integrating it.
Hello Maarten, could you maybe explain if what you were trying to do with Anna as a multi-room thermostat was successful? And what have you found out since in trying to implement it? Have you maybe tried other hardware?
The reason I’m asking is because I’m trying to design a system for heating rooms in the home using probably Plugwise Anna or Adam and Tuya Zigbee radiator valves, connected with Deconz. But I can’t judge whether I would be able to use Anna or Adam to heat specific rooms using software thermostats and radiator valves.
