How to Choose the Right Zemismart Roller Shade Motor (Matter / Zigbee / WiFi Guide)
Smart roller shades are one of the most popular automation devices in modern smart homes. Once installed, they can be integrated with platforms like Home Assistant, allowing blinds to open or close automatically based on schedules, sunlight, or scenes.
However, choosing the right motor is not just about the smart home protocol. A good starting point is to think about two things:
:one: How you want to control your blinds
:two: Whether your existing roller shade hardware is compatible
This guide walks through both steps and introduces several Zemismart roller motors designed for different setups.
1. Start From Your Smart Home Ecosystem
The first step is deciding how you want your blinds to integrate with your smart home system.
There are currently three common options:
Protocol Best For
Matter over Thread Best integration with Home Assistant and modern ecosystems
Zigbee Stable mesh network and mature ecosystem
WiFi Simple setup for beginners
If your goal is tight integration with Home Assistant and local automation, Matter-based devices are usually a great choice for small installations or new smart home setups because they integrate easily across multiple ecosystems.
For larger installations with many devices, a Zigbee network with the M6 hub can still be a very reliable solution thanks to Zigbee’s mature mesh networking.
2. Check Your Installation Environment
Before choosing a motor, it is important to verify the physical compatibility of your roller shades.
The three main things to check are:
Tube Diameter
Most retrofit motors must fit inside the aluminum roller tube.
Common tube sizes include:
  • 20 mm
  • 25 mm
  • 28 mm
  • 38 mm
The motor must match the tube size to install correctly.
Blind Weight
Larger or heavier blinds require motors with higher torque.
Small blinds → small motor
Large blinds → larger motor
Power Type
Motors may be:
  • battery powered (internal battery)
  • plug-in powered
3. Recommended Matter Motors (Best for Home Assistant)
If your main goal is to integrate blinds with Home Assistant automation, Matter motors are the most straightforward option.
These motors support Matter over Thread, enabling local communication and cross-platform compatibility.
MT15B – Compact Matter Thread Roller Motor
Best for smaller blinds and tubes.
Features:
  • Matter over Thread
  • internal rechargeable battery
  • compatible with 20 / 25 / 28 mm tubes
  • ideal for small or medium roller shades
Typical usage:
  • bedroom blinds
  • kitchen blinds
  • smaller windows
MT25B – Larger Matter Roller Motor
Designed for larger blinds.
Features:
  • compatible with 38 mm aluminum tubes
  • higher torque for heavier shades
Typical usage:
  • living room blinds
  • large window roller shades
  • zebra blinds
Quick Comparison
Model Tube Size Best Use
MT15B 20 / 25 / 28 mm smaller blinds
MT25B 38 mm larger blinds
If you want the best compatibility with Home Assistant, these two Matter motors are usually the first options to consider.
4. Zigbee Motors (Stable Mesh Network)
Another option is Zigbee motors.
Zigbee devices form a mesh network, which can improve reliability in larger homes because devices relay signals between each other.
Zemismart Zigbee motors can connect to Home Assistant through the Zemismart M6 gateway.
ZM25Z – Zigbee Plug-in Motor
Key features:
  • Tuya Zigbee protocol
  • plug-in power supply
Best for:
  • large roller shades
  • installations where power is available nearby
ZM15B – Zigbee Battery Motor
Features:
  • Tuya Zigbee
Best for:
  • smaller blinds
  • battery powered installations
5. WiFi Motor (Beginner Friendly)
For users who are just starting with smart home devices, a WiFi motor can be the simplest option.
ZM25WB – Tuya WiFi Roller Motor
This is a newer model designed for entry-level smart homes.
Features:
  • Tuya WiFi connectivity
  • internal battery
  • compatible with 38 mm tubes
Best for:
  • single blind installations
  • users starting their first smart home device
WiFi motors usually require less setup but do not offer the same mesh networking benefits as Zigbee or Thread.
6. Quick Selection Guide
Here is a simplified way to choose:
Scenario Recommended Model
Best integration with Home Assistant MT15B / MT25B
Small blinds (20-28 mm tube) MT15B or ZM15B
Large blinds (38 mm tube) MT25B or ZM25Z
Zigbee mesh network ZM25Z / ZM15B
Beginner WiFi setup ZM25WB
7. Final Thoughts
Choosing the right smart roller motor usually comes down to three factors:
:one: smart home protocol
:two: tube diameter
:three: blind weight
For users focused on Home Assistant automation, Matter motors like MT15M and MT25B provide the most direct and future-proof integration.
For users already running Zigbee networks, models like ZM25Z and ZM15B offer reliable mesh connectivity.
And for beginners entering the smart home space, the WiFi-based ZM25WB can be a simple starting point.
We appreciate feedback from Home Assistant users and makers who are interested in testing and sharing their setup experience.
When you write “MT15M”, you mean “MT15B”, right?
What about the newer MT16B? Isn’t it preferable to the MT15B?
It doesn’t have that thing hanging loose, and it has USB-C instead of Micro-USB. Unfortunately, the piece that sticks out is apparently a little wider.
I’m having a hard time finding the exact measurements.
How many millimeters are the MT15B and MT16B on the piece that sticks out? (The part where the USB connector is.)
This is relevant, as my roller blinds sit inside the window frame itself.
hi kindly check the attachment, i attched two pic for you to refer the size.
Are you planning to update the MT25B roller blind software to Matter 1.3, 1.4, or 1.5? The device often doesn't respond when needed. I have automation set to open and close the blinds. The blind doesn't always open or close. The eve motionblinds 20caa9901 blinds always work. The MT25B roller blind has a problem twice a week.
Do you have multiple roller blinds operating in one space?
Thank you for your detailed guide about Zemismart Roller Shades. I want to add roller shades to my HA install and yours are on my to-do research list, but I haven’t gotten around to looking into it so this is a timely post for me.
I’m interested in wifi or zigbee motors and I have a couple of questions:
  1. Are they local control without cloud?
  2. Do they require an app to install?
Thank you for your kind words! I'm glad the guide was helpful and arrived at the right time for your research :blush:
Yes — our Zigbee roller shade motors can work fully locally without any cloud connection when paired directly with platforms such as Home Assistant via Zigbee2MQTT or ZHA.
For the Zigbee version:
• No internet connection is required for normal operation
• No Tuya cloud is required
• You do not need to use the Zemismart or Tuya app after pairing
• Local control and automations in Home Assistant work normally
For the WiFi version:
• Initial setup usually requires the Tuya/Smart Life app
• Some users later integrate them locally with Home Assistant, but Zigbee is generally the preferred option for fully local control
Since you are already using HA, I would personally recommend the Zigbee version for the best local experience.
However, please kindly check with our store/customer support before purchasing, as not all of our motor models support fully local control or direct Zigbee integration.
Yes,
I have two roller blinds in one room: an Eve and an MT25B. The problem is only with the MT25B blind.
Thank you for the detailed information.
We understand that your MT25B roller blind sometimes fails to respond to automations, occurring about twice a week, while your Eve MotionBlinds work normally.
We will forward this issue to our technical team for further investigation. Regarding Matter 1.3, 1.4, or 1.5 firmware support, we will also check the current update plan and get back to you as soon as we have confirmed information.
Thank you for your patience and for helping us improve the product.
Did you automate the process using Home Assistance?
Besides automation, are there any issues with normal controls?
I have my automations set up in the SmartThings Hub.
The problem occurs with both automations and manual control. It seems like the blinds don't respond to the first command. The blinds only respond after clicking the icon in Home Assistant or the SmartThings app 2-3 times.
Hey Zemi. Are there any firmware updates for the Zemismart MT25B? We have ten of these in our apartment connected to HA using OBTR for Matter over Thread. We get a LOT of dropouts that never return, and I end up having to start over and create a new device in HA each time.
A quick example today: I can ping this roller and see it on the thread network, but it’s not responding to the Matter server. It’s offline and has been for hours. I only reconnected it earlier today after it had failed the other week.
