At the moment, I can only cast the default dashboard. I can’t find a way to change to an alternate.
I’d like to set a minimal dashboard just for the Google cast.
How do I do this?
How do I do this?
When you are at the cast website (after authenticating etc. ) you should have an option for which of your views to cast.
if trying to automate:
Be sure you have a title assigned to your view:
You can also do it via the cast option in the entities card
Thanks for the reply. I have that. What I don’t have is which dashboard and the view to choose, only the views on the default dashboard.
I can select the default dashboard on other devices but not when casting. That’s the bit I’m missing.
Is it not possible without writing yaml?
Did you ever figure this out? I’m having the same issue.
I can only cast to the dashboards that are in “overview” none of my other dashboards show as an option for casting.
