How to clean / delete sensors ? (open hardware monitor)
I did a few hardware changes on my box and some OHM sensors do not exist anymore. But log gets spammed with:
Logger: homeassistant.helpers.entity
Source: components/openhardwaremonitor/sensor.py:92
First occurred: 20 janvier 2022, 10:35:31 (9268 occurrences)
Last logged: 09:42:35
Update for sensor.boba_asus_prime_z690_p_d4_nuvoton_nct6798d_fans_fan_6 fails
Update for sensor.boba_amd_radeon_r9_380_series_clocks_gpu_memory fails
Update for sensor.boba_amd_radeon_r9_380_series_temperatures_gpu_plx fails
Update for sensor.boba_amd_radeon_r9_380_series_temperatures_gpu_hot_spot fails
What is the best way to remove those sensors?
Thank you in advance.
Find, filter and delete them at Link to Entities – My Home Assistant
I tried before asking, I can’t find a way to remove them, they are read-only.
Hey,
Did you find a way to delete them ? Also is it possible to limit the data log interval seems like the default is 30 seconds.
