Say I have multiple thermostats, is it possible to create one virtual thermostat so I can send an API request to only one ID?
thank you.
thank you.
I’m using climate group custom component for this purpose. It’s also available on HACS.
Just putting out there that i had the same problem and the given solution there is not oficially supported by the creator anymore and for me rn HVAC Group (which can be installed through HACS) works wonderfully
Looks like this has been retired from HACS. I am questing for a solution.
I just tried the HACS “Better Thermostat” integration to link multiple zigbee thermostats. So far so good.
