How to compare a input counter state with a input number in a blueprint?
Hello everyone.
I’m trying to configure a new Blueprint to set actions when pressing a Philips Hue controller.
I’m facing a knowledge gap in here. My goal is be able to receive as input and counter and a number and in the actions compare the “state” of the counter (0, 1, 2…) with the received number (like a index number).
Blueprint:
blueprint:
  domain: automation
  input:
    clickCounter:
      selector:
        entity:
          filter:
            domain: counter
    scene_index:
      name: Scene Index (in Click Counter)
      selector:
        number:
          min: 0
          max: 10
          mode: box
          unit_of_measurement: index
triggers:
actions:
  # - variables:
  #     selected_mode_var: !input scene_index
  - if:
      - condition: state
        entity_id: !input clickCounter
        state: !input scene_index
       # THIS VALIDATION IS WHAT I'M TRYING TO SOLVE
       # this not work, I've also tried with variable and template, but so far I wasn't able to figure it out
    then:
      # do something
      - stop: Nothing to do
I out of ideas in how to compare the counter with the number.
Could someone help me? Thanks a lot!
States are always strings, the number selector returns a number… you need to use templating to convert a number to a string, so you will need to define script variables for both inputs and use a Template condition.
blueprint:
  domain: automation
  input:
    click_counter:
      selector:
        entity:
          filter:
            domain: counter
    scene_index:
      default: 0
      selector:
        number:
          min: 0
          max: 10
          mode: box
triggers:
actions:
  - variables:
      counter_ent: !input click_counter
      index_num: !input scene_index
  - if:
      - condition: template
        value_template: "{{ is_state(counter_ent, index_num | string) }}"
    then:
      # do something
WOW!
It works! Thanks a lot bro!
You were spot on.
