I’m setting up a complex automation to handle the best charging approach for my house…I would like to perform a status check between sensor to check if a “selected” value in a sensor in a certain time is aligned with offical sensor… below the code i wrote but seems not working because the result is always negative. what is wrong?
- if:
- condition: and
conditions:
- condition: state
entity_id: input_boolean.ignora_consumi
state: "on"
- condition: or
conditions:
- condition: state
entity_id: input_select.fascia_selezionata
state: Tutte
- condition: state
entity_id: sensor.pun_fascia_corrente
state: "{{states('input_select.fascia_selezionata')}}"
then:
- service: switch.turn_on
data: {}
entity_id: switch.presa_di_ricarica_auto
else:
