How to concatenate strings with variables in config-template-card template
Dear All,
I have a working template card like this:
  - type: 'custom:config-template-card'
    variables:
      number: states['sensor.vpnclients'].state
      timeStamp: states['sensor.vpnclients'].attributes.lastUpdated
      titlePrefix: '''Connected clients at '''
    entities:
      - sensor.vpnclients
    card:
      type: custom:list-card
      entity: sensor.vpnclients
      title: "${ vars['timeStamp'] }"
      feed_attribute: clients
      columns:
        - title: Name
          field: field1
        - title: Virtual IP
          field: field3
          style:
            - text-align: center
        - title: Remote IP
          field: field2
          style:
        - title: Bytes received
          field: field4
          style:
        - title: Bytes sent
          field: field5
          style:
        - title: Connected since
          field: field6
          style:
I would like to change the title of the card to display something like this:
Connected clients at 12:34
What is the correct way to achieve this? I tried this:
title: "${ vars['titlePrefix'] vars['timeStamp'] }"
and this:
title: "Connected clients at ${ vars['timeStamp'] }"
but it is sooo bad, that the card stopped rendering altogether…
Any pointers are much appreciated!
I think you will find your answer here:
Thank you, it worked like this:
    variables:
      - '''Connected clients as of '''
      - states['sensor.vpnclients'].attributes.lastUpdated
    entities:
      - sensor.vpnclients
    card:
      title: '${vars[0] + vars[1]}'
      columns:
What I don’t understand is why it doesn’t work like this too:
    variables:
      prefix: '''Connected clients as of '''
    entities:
      - sensor.vpnclients
    card:
      title: '${vars[prefix] + vars[timeStamp]}'
      columns:
Thank you for the tip!
Hi
Came across this when looking for a way to join two states together to overcome the 255 character limit.
Read your question on why it wasn’t working and I think this is why;
The working one
stores the variables as (likely a string data type) and adding them together isn’t an issue.
but the second one is attempting to add a string to a datetime object. I’d guess that if anyone else has this issue, you could try forcing the datetime object to be typecast into a string.
Best of luck tho - sorry for reviving such an old thread!
It worked for me using:
 ${[prefix] + [timeStamp]}
