How to condense these scripts/automations?
Is there anyway to dondence these into a single script/automation?
script1:
  alias: Living Room
  sequence:
    - service: switch.turn_on
      entity_id: switch.sonoff04
    - delay: '{{ states.input_number.hours.state | int }}:00'
    - service: switch.turn_off
script2:
  alias: Man Cave
  sequence:
      entity_id: switch.sonoff03
script3:
  alias: Bedroom
  sequence:
      entity_id: switch.sonoff01
- id: 1xxgsfgh
  alias: Turns off LR timer
    platform: state
    to: 'off'
  - service: homeassistant.turn_off
    entity_id: script.script1
  - service: input_select.select_option
      entity_id: input_select.radiator
      option: None
- id: 1xdfst
  alias: Turns off MC timer
    platform: state
    to: 'off'
    entity_id: script.script2
      option: None
- id: 111xrethn
  alias: Turns off Bedroom timer
    platform: state
    to: 'off'
    entity_id: script.script3
      option: None
Use 1 automation in conjunction with a script that accepts variables.
Script:
variable_script:
  alias: Any room
  sequence:
      data_template:
        entity_id: {{ my_variable_entity_id }}
      data_template:
Automation:
    platform: state
    entity_id:
      - switch.sonoff04
      - switch.sonoff01
      - switch.sonoff03
    to: 'off'
    data_template:
      entity_id: script.variable_script
      my_variable_entity_id: "{{ trigger.entity_id }}"
      option: None
This uses triggers for templates, read up on them here:
Or, for ultimate condensement, incorporate the script as the action of the automation…
- id: 1xxgsfgh
    platform: state
    entity_id:
      - switch.sonoff04
      - switch.sonoff01
      - switch.sonoff03
    to: 'off'
      data_template:
        entity_id: {{ trigger.entity_id }}
      data_template:
        option: None
aww thank you so much. I don’t really understand variable trigger thing but i’m going to give it a try.
Out of interest, why does this not work?
I get this error
Invalid config for [script]: Entity ID switch.{{states.input_select.radiator.state}} is an invalid entity id for dictionary value @ data['script']['script10']['sequence'][0]['entity_id']. Got 'switch.{{states.input_select.radiator.state}}'. (See /config/configuration.yaml, line 30). Please check the docs at https://home-assistant.io/components/script/
# Input Select
  radiator:
    options:
     - None
     - Living_Room
     - Man_Cave
     - Bedroom
     - All
    initial: None
    icon: mdi:radiator
# Radiator - Input Select
  - alias: Radiator - Input Select
      - platform: state
        to: Bedroom
      - platform: state
        to: Man_Cave
      - platform: state
        to: Living_Room
        entity_id: script.script10
# Script
script10:
  alias: 'Radiator - Input Select'
  sequence:
      entity_id: 'switch.{{states.input_select.radiator.state}}'
This returns a yaml error
Error loading /config/configuration.yaml: invalid key: “OrderedDict([(‘trigger.entity_id’, None)])”
in “/config/automations.yaml”, line 14, column 0
this gave the same error so i assume that i have done something wrong.
Is it to do with my_variable_entity_id? Where do you define this?
because you have templates outside template sections in your script, and your input select selections are uppercase. All entity id’s are lowercase, you need to use the lower filter as well.
script10:
  sequence:
should look like this:
script10:
  sequence:
      data_template:
        entity_id: 'switch.{{ states.input_select.radiator.state | lower }}'
      data_template:
That’s because he made a minor typo, the code in the entity_id sections need quotes:
- id: 1xxgsfgh
    platform: state
    entity_id:
      - switch.sonoff04
      - switch.sonoff01
      - switch.sonoff03
    to: 'off'
      data_template:
      data_template:
        option: None
It’s defined in the automation if you copied it properly. I wrote it off the top of my head, so there could be errors. Without the errors, I can’t help you debug it.
I think I have confused things so if you still don’t mind helping me I want to clear a few things up.
  • I have 4 sonoff switches which I want to control manually to turn on/off the radiators at any time.
  • I want an Input_Select which has a drop-down menu of my switches and when an individual switch is selected I want it to turn on that switch for the period of time which is decided by the input_number slider.
  • I want to also be able to cancel the "Hours/Timer" period if I manually turn off the switch.
  • I also want the input select to revert to "None" once a specific radiator has been selected.
I had it all set up before but it involved something like 6 automations and 3 scripts so i was hoping it could be down with fewer things and i could also learn from this in the future.
I would really appreciate if you were able to help.
  radiators:
    entities:
      - switch.bedroom
      - switch.living_room
      - switch.man_cave
      - switch.switch3
      - input_number.hours
      - input_select.radiator
So you don’t want the switches to only turn the radiators on for the interval? You only want the dropdown to have this functionality?
yes that’s it!
So when its really cold I can turn them on for the night. But, if its a little bit cold i will use the timer to put them on for 1 hour.
what are your radiator selections in the input_select?
  radiator:
    options:
     - None
     - Living Room
     - Man Cave
     - Bedroom
     - Hall
     - All
    initial: None
    icon: mdi:radiator
  1. Providing a solution so that “All” works is extremely complicated with just Yaml. It’s possible but it would require a loop and a counter. It ends up being a ton of work and I don’t have a python script handy at the moment that solves that issue.
  2. This solution will only work for 1 switch at a time. Meaning you cannot have multiple heaters on a timer on at a time. If you want that, then you cannot merry them into a single script. You have to have a separate script for each one. You only have 1 script. If the script is running and you use the dropdown again, the currently running script may get canceled. I haven’t tested it out, it may behave differently.
  3. Probably want to split the automation up again because having it combined means you’ll have to have a bunch of data templates.
split method:
automation:
- id: 1xxgsfgh
    platform: state
  condition:
    condition: template
    value_template: "{{ trigger.to_state.state in [ 'Living Room','Man Cave','Bedroom','Hall'] }}"
    - service: script.timed_radiator
      data_template:
        radiator: >
          {% set radiators = {
            'Living Room':'switch.living_room',
            'Man Cave':'switch.man_cave',
            'Bedroom':'switch.bedroom',
            'Hall':'switch.switch3' } %}
          {{ radiators[trigger.to_state.state]] }}
script:
script:
  timed_radiator:
    sequence:
      data_template:
        entity_id: "{{ radiator }}"
      data_template:
        option: None
combined method:
- id: 1xxgsfgh
    platform: state
  condition:
    condition: template
      data_template:
        entity_id: >
      data_template:
        entity_id: >
        option: None
Thank you sooo much! It works great.
please let me ask this related script variable passing:
when this condition passes:
  - condition: template
    value_template: >
      {{trigger.to_state in ['group.daughter1', 'group.daughter2', 'group.daughter3',
                            'group.daughter4', 'group.wife'] }}
id like to have an announcement be made:
service_template: >
  script.announce_{{'daughters'  if trigger.to_state in ['group.daughter1', 'group.daughter2', 'group.daughter3',
                        'group.daughter4'] else 'wife'}}
    data_template:
      variables: >
        presence_person: "{{trigger.to_state}}" # or trigger.entity_id?
        presence_location: "{{trigger.to_state.state}}"
script.announce_daughters:
  sequence:
    service: notify.ios_telefoonmhb
    data_template:
      title: '{{presence_person}} arrived home speech'
      message: >-
        {{as_timestamp(now()) | timestamp_custom("%X") }} :
        {{ person}} arrived {{presence_location}}.
        push:
          sound: US-EN-Morgan-Freeman-Daughter-Is-Arriving.wav
  script.announce_wife:
    sequence:
     title: 'Wife Arrival notification'
        message: 'Your wife is arriving' #{{ trigger.zone.attributes.friendly_name }}
          push:
            sound: 'US-EN-Morgan-Freeman-Wife-Is-Arriving.wav'
now where do I create the variable using the trigger.to_state and how to place it in the data_template of the script daughter (no variable needed in the wife script, only one there :wink: )
@petro @pnbruckner would you please have a look, I am a bit stuck here… one of my daughters came home, and it selected the wife script… (apparently the condition isn’t correct) and it didnt pass the variables either.
TL; DR. But first, this doesn’t make any sense:
    value_template: >
trigger.to_state is a state object, not a state string. It will not match anything in a list of strings. I’m guessing you meant trigger.to_state.state, but that’s not clear since you don’t show the trigger.
Second, when you call a script using its name as the service, you don’t put variables under variables:. You just list them directly under data: or data_template:. This is clearly explained here.
No, I meant trigger.to_state, and my trigger is:
  - alias: Presence Tracking
    id: 'Presence Tracking'
      platform: state
      entity_id:
        - group.daughter1
        - group.daughter2
        - group.daughter3
        - group.daughter4
        - group.wife
        - group.me
I want the automation to create to variables, presence_person (trigger.to_state) and presence_location (trigger.to_state.state), and pass these to the scripts.
tbh it isn’t as clear as you say, since I need the triggers to be passed? If you point me to the 'variables: ’ error, you’re right, I’ve taken that out.
seems to work now with this:
    value_template: >
      {{trigger.entity_id in ['group.daughter1', 'group.daughter2', 'daughter3',
                            'group.daughter4', 'group.wife'] and
                            trigger.to_state.state == 'home'}}
  - service_template: >
      script.announce_{{ 'daughters' if trigger.entity_id in ['group.daughter1', 'group.daughter2', 'group.daughter3',
    data_template:
      presence_person: "{{trigger.entity_id.name}}"
and the 2 scripts:
  announce_daughters:
    sequence:
      data_template:
        title: >
        message: >
          {{-as_timestamp(now()) | timestamp_custom("%X") }} :
          {{- presence_person}} arrived {{presence_location}}.
          push:
            sound: >
  announce_wife:
    sequence:
      data_template:
     #        title: 'Wife Arrival notification'
        message: 'Your {{ presence_person}} is arriving {{presence_location}}' #{{ trigger.zone.attributes.friendly_name }}
          push:
            sound: >
