could you please help me to configure the FGK10x Door sensor?
My goal is to obtaining a notification when the window is opened or the shutters is moved.
So I’m going to connect an external sensor to the FGK10x. How can I connect it?
I’m using a Raspberry where I have installed Home-Assistant and I have plugged a Z-Stick Gen5 as controller.
Further I have a node connected to the controller, the Fibaro FGK10x Door sensor.
If I’m moving the magnet, the sensor icon turn on an icon and “Fibaro … Access Control” icon changes the value to 22.
While if I connect the shutters sensor to IN and GND inputs, the magnet sensor stops to working and if I move the wire sometimes the sensor icon turn on.
In this link you can find out the node configuration file.
I have also tried to create a post in the fibaro community.
Please help me.
Francesco
