I have integrated one of two Edimax switches in my Configuration.yaml with the following code. It works like expected. But somehow I don’t seem to be able to integrate the second switch with IP 192.168.1.90. I have tried various ways but did not succeed. Solutions anyone?
Now I can see and operate the switches in the entity section of settings.
Open question for me. I can manually operate the switches in the entity section, but they are not visible in the automation section. An integration is missing ?
Hi, I am currently trying to get my Edimax 2101 V2 to work.
The first one can now sucessfully be switched from HA but for whatever reason I do not see any actual current values. @JosephusZanders , @Winfried3 , have you seen actual watt values from your switch?
